HIgh mileage
Old May 24, 2011 | 07:34 PM
Ironhauler's Avatar
Default HIgh mileage
I have 338000 on my 6.0 what should I do to preserve its life
Old May 24, 2011 | 07:58 PM
Mdub707's Avatar
I'd say keep doing whatever you're already doing, cause it's working...
Give us some info about the truck, what mods do you have, how do you use it, what do you want to do, and what's the budget? Need info dude!
Old May 24, 2011 | 08:55 PM
BIG NIG's Avatar
buy a lottery ticket
Old May 24, 2011 | 08:59 PM
Ironhauler's Avatar
Well I use the truck for personal and recreation use. Curantly it stock, but I would like to start with some 4in exhaust turbo back then some head studs and from there id like to keep it reasonable so my wife can drive but fun for me and for the budget I like the most for the least hopfully im not the only one... Right
Old May 24, 2011 | 09:10 PM
PSD-BLACK-CLOUD's Avatar
Man yours has the most miles and is still running i have ever heard of
Old May 24, 2011 | 09:32 PM
Mdub707's Avatar
Headstuds isn't necessary if you've gone this long, unless you're putting a hot tune in. What's the maintenance like on this? When's the last time coolant was flushed? What about trans?
4" exhaust is good, coolant filter is a good idea, fuel pressure gauge is a good idea (other gauges if you want to tune it) and engine oil temp and engine coolant temp too. Full EGR delete wouldn't hurt either.
yes, buy lottery ticket...
Old May 24, 2011 | 10:10 PM
Ironhauler's Avatar
I did notice last weekend when I had the coolant out changing the injectors that there was some small amounts of an oily substance in the bottom of the buckets and also the water was greenish black but not milky.. So I wasnt sure really what it was I wanted to belive that it was from a stuck egr but I really dont know and the tranny seems fine no slips always positive shifts and the filter and pan were both clean... Oil every 7000 mobil delvac 1300 15/40 & 1gallon lucas and yes I do need some leads on good egr delete and the exhaust if you know of any
ANd if I wanted to tune... What would be the first step? Overhaul...
Last edited by Ironhauler; May 24, 2011 at 10:10 PM. Reason: Automerged Doublepost
john grossman
10
Jan 12, 2019 08:58 PM
Blackdog15
May 20, 2015 10:49 PM
robbyS
Apr 16, 2015 02:22 PM
TheBeattie
Dec 24, 2014 11:22 PM
Dirty Offio
Big Rigs & Semis
Nov 4, 2014 07:43 PM
