Improving exhaust brake stopping power...
Old May 23, 2011 | 11:55 PM
95.12v.Cummins's Avatar
Default Improving exhaust brake stopping power...
I love my BD exhaust brake, I'm curious if theres any way to increase the power of the exhaust brake such as adding stronger valve springs. My truck has the 60lb springs on it would upgrading to the Hamilton Cams valve springs help hold my truck back while going down a grade?
Old May 24, 2011 | 08:29 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
the reason you have to put heavy valve springs in is to keep from floating valves. you got that covered already.
Old May 25, 2011 | 12:06 AM
So is there any way to increase the strength of the brake?
Old May 25, 2011 | 08:20 AM
diesel pap's Avatar
not that i know of
Old May 25, 2011 | 12:46 PM
Blair@BD's Avatar
FormerVendor
No 60# is the max limit, unfortunately.
Old May 28, 2011 | 08:59 PM
Dang oh well, still love the brake
Old May 28, 2011 | 10:21 PM
geddy's uncle's Avatar
Downshifts. How's your clutch?
Old May 29, 2011 | 10:34 AM
Im in need of a new clutch, with what im planning 13125-fek south bend clutch. Along with a set of sdx injectors 5x014s and a 60mm upgrade tto my Wh1c, with a timing bump to around 15*-16* along with a kdp fix when I do the timing. Just curious what kind of horsepower should I expect? I do tow but fairly rarely, just a boat and a 28ft camper. Basically going to be a fun daily driver
Old May 29, 2011 | 01:42 PM
cumminspwr11's Avatar
i think the 5x14s will be kinda hot with that 60mm turbo, with my set up in my sig i run about 5-700 cursing no load, i have the tractor its about 800, and if im doing 75-80+ on a grade with the tractor its about 1200 but those numbers are all post turbo
Old May 29, 2011 | 08:29 PM
So what kind of HP are you looking at? and what is the HX40?
What kind of turbo would you recommend to run with the 5x014s?
Last edited by 95.12v.Cummins; May 29, 2011 at 08:29 PM. Reason: Automerged Doublepost
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jun 26, 2015 10:30 AM
