About to buy 2005 6.0
Old May 23, 2011 | 10:53 AM
vr4extrm's Avatar
Default About to buy 2005 6.0
Hello everyone new to the forum and have been reading alot about the 6.0 and have alot of reservations. I am looking to buy a 2006 F-250 6.0 with 80k. I have heard nightmare senerios about the 6.0. I was wondering if I where to buy it what would be the first thing I need to do to up my chances of a long engine life, by what I have read it sounds like the EGR delete. Also Go to a HP oil pump or is it just parts to the oil pump that need to replace or the whole assembly? I am really just going to be pulling horse trailers and such no real massive pulls planned. I would appriciate any help I can get. Should I run or put a few bucks in it and have a good reliable engine?
Thanks
Old May 23, 2011 | 11:00 AM
PSD-BLACK-CLOUD's Avatar
Get an oasis report on it. I wouldnt buy another one. Had 2 Its a constant 500 to fix this 1000 to fix that then you blow your heads or lose a few injectors. If you spend a few grand on it it is a good engine. I would buy a 6.4 tune and delete the dpf and egr.
Old May 23, 2011 | 11:19 AM
vr4extrm's Avatar
Default correction
Its a 2006 if that changes anything. Oasis report is clean.
Old May 23, 2011 | 11:40 AM
I had on 04 and an 06. Their are alot of guys who love their 6.0's and swear buy them. Like I said a few grand and you should be ok. And I wouldnt pay more than 18 for it at the most. Because I got 13,300 when I traded my 06 in with 128,000 on it.
Old May 23, 2011 | 11:55 AM
Mdub707's Avatar
And then blow the headgaskets from too much backpressure since you deleted the EGR without put a wastegate in? Not sure how that will end up any different than the 6.0. You can block it off and be OK, but still an issue on the hot tunes.
I agree, get an Oasis report first.
What are your plans for the truck? Is this something you want to mod and hot rod, or just a stock tower, or what?
Old May 23, 2011 | 11:57 AM
I never had any issues out of either of my 04 or 05 6.0 Powerstrokes.
Old May 23, 2011 | 12:03 PM
vr4extrm's Avatar
Default Plans
I just plan to have it as a stock puller not really looking to do much. Ive been researching a while because of the things I have heard. What I am Kind of getting is delete the EGR and get a cooler bypass. A Little confused about the oil cooler though is it just the bits and pieces that need replaced our the whole system. Or does that even need to be done with a bypass cooler installed. Thanks for any help I have read almost the whole forum and I know alot of things have been asked I am just tring to get it all down in one place where I can read it.
Old May 23, 2011 | 12:25 PM
Mdub707's Avatar
Check the Oasis first, it could be a problem truck, or it might be clean, never know. If you're going to run it stock, I'd get a coolant filter, a full egr delete, if you can, and while I was in there, I'd just throw a new oil cooler in, just to be safe. See if the STC fitting update has been done or not, if not, I would do that while it was apart. Other than that, it should be a pretty reliable truck. A good 4" turbo back exhaust, some gauges and an SCT with custom tuning wouldn't hurt either. You can get good solid towing tunes that don't add a lot of power, but help the trans tremendously.
IMO, the most important thing you can add to any 6.0 is a fuel pressure gauge. This will protect your expensive injectors.
Old May 23, 2011 | 01:53 PM
vr4extrm's Avatar
Default ok
So pretty much this (Basic Solution(TM) for Ford 6.0L Powerstroke With Sinister EGR Delete Kit, Oil Cooler and Intake Gaskets) and fuel pressure gauge and I should be good for what I plan.
Old May 23, 2011 | 01:58 PM
If you get the full delete and not just the block off plates i am prety sure it comes with a wastegate.
