KSB install
Old May 22, 2011 | 04:28 PM
lodal cummins's Avatar
Default KSB install
so i like the benifits of the M&H timing spacer over the 1/8 timing bump as it sounds like you get to keep the bottom end. but with all installs things can go wrong. i have heard of guys some how breaking the KSB. then it is a 400 dollar part. so my question would be is this a easy install or a little risky?
Old May 22, 2011 | 04:48 PM
cougar's Avatar
I did mine in less than 30 minutes. 2 things, don't loose any parts and don't damage the tube that connects to it.
Old May 22, 2011 | 06:12 PM
how many parts are in this little fella? are the mounting bolts on there pretty tight and do you have to use the hand pump to re prime the system? i would assume use lose all the fuel that is in the pump when you pull this out.
Old May 28, 2011 | 04:40 PM
cougar's Avatar
A spacer plate, a spacer washer, 2 bolts, and 2 o-rings. My bolts were not real tight. The biggest problem I had was space to work. At the time I installed it, my pump was rotated to the full retarded position. You will not loose much fuel. I didn't even have to bleed mine after.
Old May 28, 2011 | 06:06 PM
Longshot's Avatar
what does ksb stand for
Old May 28, 2011 | 06:17 PM
RSWORDS's Avatar
Its German... kalt-start-beschleuniger
Or translated loosly to cold start accelerator
Old Jul 3, 2011 | 01:28 PM
1arock's Avatar
The bolts that held mine were super tight. I broke a Snap-on torx wrench trying to get them loose. Rocky
Bigfury
Aug 1, 2015 10:29 AM
lkfldredneck
Jun 25, 2015 04:51 PM
Apr 29, 2015 08:20 AM
Gman30
Dec 27, 2014 12:46 PM
Cody Cain
Dec 21, 2014 06:50 PM
