Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
newbe with a few question
Old May 22, 2011 | 03:08 PM
jwayne13's Avatar
Default newbe with a few question
ok so im getting into the pulling scene, i pulled once this year so far didnt do the hottest (230ft) so my questions are...
i have 4:10 gears with 315/75's (at's), what gear should i pull in?
should i air down my tires, if so to what?
are ladder bars and drive shaft loops worth making?
where can i get a hitch?
Old May 22, 2011 | 03:30 PM
j_hlad's Avatar
depends on what transmission and what do you have done. A defininate yes to the traction/ladder bars, as far as air pressure, down in the front up in the back if you are looking for an adjustable hitch, i would recommend making your own but if you cant or dont want to, then try to find a camper dealer and get one from them, one with a lot of holes so you can move it around...
Old May 22, 2011 | 03:57 PM
jwayne13's Avatar
sorry for the confusion, i have a hitch i ment the recever
for a trans i got a built bd trans with a double disk converter
other mods are;
+15 Timing Advance, AFC tuned, #100 fuel plate slid forward, 3k gsk, Star wheel cranked,4" MBRP Turbo Back to 6" Tip, Waste Gate Pinch, AFE Sage 2 Intake, 215 Injectors, and gauges
and any tips for the gear, i was thinking drive,OD off, 4Lo
Old May 22, 2011 | 04:34 PM
94 12valve's Avatar
other mods are;
sounds good so far ... but add some valve springs and some 4k's, run 3rd locked and you should have a good starter puller
Old May 23, 2011 | 01:05 AM
jwayne13's Avatar
i was looking into valve springs but thts where i draw the line for now .
if i do valve springs the head will have to come off, then since its off ill have to have it ported and pollished and gone over, then since thats all done ill prrob have to studd it, thne since its studded i would have to get a bigger turbo ..
i just cant take somthing apart and put it back togother better if i know i can upgrade it to make it more bad a**
but for now i think im keepin it how it is untill i ether get a low miliage motor to replace it or a new daily
any one know what psi i should run in the tires?
Old May 23, 2011 | 11:16 AM
94 12valve's Avatar
you don't need to take the head off for valve springs, its pretty easy with the head on.
Old May 23, 2011 | 04:27 PM
jwayne13's Avatar
well in that case, anyone have a step by step how to fourm then?
also 94 12valve: i watched you one season vid and seen you pulled at the buck.. any chance you'll be there june 11th??
Old May 23, 2011 | 07:45 PM
94 12valve's Avatar
Hell yeah I will be where are you from?
here was my run at the buck this year
Old May 23, 2011 | 07:54 PM
J-Pipes's Avatar
I think your clutch may be mad at you
Old May 23, 2011 | 08:02 PM
94 12valve's Avatar
That was actually coolent ... I blew a freeze plug in the head round the 150' mark.
