HELP!! ( ENGINE MISS ) I THINK
Old May 22, 2011 | 01:49 AM
4x4fletcher's Avatar
Default HELP!! ( ENGINE MISS ) I THINK
ok guys, im a little new to the diesels, so bear with me. my truck is a 90 model crew cab CHEVY with a 92 12 valve cummins swapped in it.(check out my pics to see some of my toys) i have only had it for about a month and have just been cleaning it up and working out some of the bugs. well 1 problem that i have is that i think the engine has a miss, but im not sure. it seems like it comes and goes. it idles a little rough and if u rev it then it feels rough down low, but seems like it clears up. even when u load it up it feels the same. it kinda feels like it clears up when u stay in it. but its hard to tell, it might not be. i have tryed cracking injector lines to see if i could narrow it down to a single cylinder missfire, but no luck there. every one of them made a noticeable difference, but 2 of them werent as hard. so im not sure what to do next. i dont know if the problem is in the injectors, or could it be the valve springs? the engine is stock, i got to reading on here and found the pump mods, i did the fuel pin grind and love it. i went from 20psi of boost to 30psi. but it didnt help the miss any. so any ideas on where to look?
Old May 22, 2011 | 06:13 AM
Longshot's Avatar
get one of those infared heat guns and check the temp on each exhaust port if one is colder than the others it will be the one missing. Might help narrow it down some
Old May 22, 2011 | 02:36 PM
o.k. i shot all cylinders with a temp gun. all of them shot 180-190, except for the front 2. they shot 150- 160
Old May 22, 2011 | 05:25 PM
Marty Z's Avatar
Have the injectors checked.
Old May 28, 2011 | 08:11 AM
Longshot's Avatar
You might want to try a product called hot shot secret it is supposed to help sticky injectors truckers swear by it. If it works it's cheaper than injectors
Old May 28, 2011 | 10:58 PM
sweetv8s10's Avatar
Where do you get this hot shot secret?
Old May 29, 2011 | 11:07 AM
Longshot's Avatar
Hot Shot's Secret | Diesel Engine Oil Additive
Old May 31, 2011 | 07:08 AM
KD93's Avatar
You might try changing the fuel filter. That sounds too easy, but ALWAYS do the easiest things first!!!! If you don't have a good supply of fuel, (the filter is plugged) then it will make the engine feel like it's missing.
burndiesel
10
Feb 7, 2023 01:15 AM
Zach56238
Sep 3, 2015 06:57 AM
klein444
Jun 20, 2015 11:48 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
hunt4beer
Nov 15, 2014 09:06 AM
