low budget build
Old May 20, 2011 | 09:22 PM
94 dodge cummins's Avatar
Default low budget build
I got a 94 dodge 2500 cummins, i took the fuel plate out and waiting to tune the afc, i got pillar guages, but am wondering what i can do to it to try to get around 500hp, so any suggestions would help, thanks
Old May 20, 2011 | 11:49 PM
94Cumminz's Avatar
did you do the kdp?
Old May 21, 2011 | 04:02 AM
97cummins's Avatar
Originally Posted by 94Cumminz
did you do the kdp?
diito ^
Old May 21, 2011 | 10:25 AM
No im planing on doing that soon
Old May 21, 2011 | 05:18 PM
rallyit67's Avatar
I bet with no plate, laser cut DV's, 4gsk, rack plug, some 435 injectors, and a turbo that can flow that amount of fuel you would probably be close.
Old May 21, 2011 | 07:01 PM
ok were is the best place to get that stuff from, for a reasonable price.
Old May 22, 2011 | 09:08 AM
monster12valve's Avatar
sponsors
Old May 22, 2011 | 01:21 PM
1SlowCTD's Avatar
To get your truck to 500HP I would run a 62/71 at the minimum, but a 64mm would work better, with a set of 5*0.014"s. Run in the neighborhood of 18* of timing. This would be a very strong setup until you blow your headgasket. I also suggest head studs for the boost a 62 or 64 can produce. Stay away from junky laser cut DV's as all they do is produce heat and smoke. A set of Smokem DV's will be all you will ever need. A rack plug is not a must as you don't really need the extra rack travel, it's just something to add if you want and is cheap($12). As far as where to get the stuff at, I tend to say ME but that is because I'm a little biased.
Nick
LBDP
Old May 22, 2011 | 02:11 PM
rallyit67's Avatar
Yeah, I ran Laser cuts and 435's and it was pretty damn smokey. I had a small twins setup but never dyno'ed the truck but it sure was fun.
Definately get studs. They are easy to put in and then you don't have to worry about blowing a HG unless you decide to go for twins they you'll prob want to o-ring. My setup was pushing a little over 70 pounds.
Old May 30, 2011 | 01:11 AM
Lostnwalmart's Avatar
Laser cuts are nasty
