lowww boost?????
Old May 20, 2011 | 09:56 AM
arobertson's Avatar
Default lowww boost?????
I have tried two different gauges and all i can get is 18 psi of boost. I have my gauge plugged into the intake manifold closest to the inercooler tube. I have a needle valve on the tube to the wastegate so I have no wastegate. Do I need to plug my gauge somewhere else? Is a needle valve bypassing the wastegate?
Old May 20, 2011 | 11:25 PM
Brandon J's Avatar
Is everything stock still. When i had still had the stock turbo and a banks box on my 01 the most that i could get was 20-22 psi.
Old May 21, 2011 | 10:18 PM
dukeboy_318's Avatar
unless you have a boost fooling box, you wont see much over 18-22, factory settings in the computer have the engine cut back at 18lbs read from the map sensor. Plugging the wastegate gets you nothing without a boost fooling program to trick the motor into not de-fueling.
Old May 23, 2011 | 06:39 AM
arobertson's Avatar
I have a superchip and a bullydog dog chip on it. The bullydog chip has a boost fooler in it. I have the wastegate line plugged too so i don't know. Maybe my boostfooler ant working.
Old May 23, 2011 | 10:17 AM
RAW's Avatar
RAW
If the Pooperchip and puppy chip both have boost fooling, it may effect your performance. I'd suggest removing the superchip software and see what happens. Some guys have tried a boost fooler with the boost fooler of a fuelling box and it doesn't work very well.
Old May 23, 2011 | 05:29 PM
72fj's Avatar
Default low boost?
you do not need to fool computer!!! no speacial do dads needed.check your boost psi sender on left side of head or buy a new one,keep the axtra one for spare in case needed in boonys!most common low power complaint.#2 buy your self a banks big head waste gate
actuator and in stall night and day.next drill 1/8 npt hole in intake elbow on intake and plumb in this spot. that will take care of that and will respond much,much better!!!!!!!!
see ya.
Old May 23, 2011 | 05:34 PM
RAW's Avatar
RAW
You most certainly do need to. The factory software defuels the engine, most I could ever make is 22PSI with a plugged wastegate without boost fooling.
Why do this? Assuming he has an HX35, there is already a 1/8" NPT port on the compressor housing.
Old May 23, 2011 | 08:27 PM
72fj's Avatar
Default low boost?
no you dont put in the compressor housing/you put the hole in the intake elbow that bolts to the intake plate on l/side of engine!!! then plumb in your boost gauge line to that. there is no need to fool the ecm unit.i get 20-30psi every day.its the most simple way to get more boost/little better mpg and still have stock peramertures.....
Old May 23, 2011 | 08:34 PM
RAW's Avatar
RAW
Why? Why drill another hole when there is already one that is easy to access?
Direct from a Dodge/Chrysler service manual.
MAP SENSOR
DESCRIPTION - DIESEL
The MAP sensor is installed into the rear of the
intake manifold (Fig. 31).
OPERATION - DIESEL
The MAP sensor reacts to air pressure changes in
the intake manifold. It provides an input voltage to
the Engine Control Module (ECM). As pressure
changes, MAP sensor voltage will change. The
change in MAP sensor voltage results in a different
input voltage to the ECM. The ECM uses this input,
along with inputs from other sensors to provide fuel
timing, fuel control and engine protection. Engine
protection is used to derate (drop power off) the
engine if turbocharger pressure becomes to high.
Thats a pretty broad range! I guess I get 40-60 every day, as long as the EJWA does it's job boost fooling.
Old May 23, 2011 | 09:32 PM
see ya.
First of all, yes you do, you have to over ride the factory boost defuel point. The only way to do that is by tricking the ECM. #2 theres zero need to drill a 2nd hole, unless hes running a nongated hx35 which he would of had to put on cause they came with factory waste gates in..
