Lifts, Wheels, and Leveling Kits
Old May 20, 2011 | 08:28 AM
madcreekfarm's Avatar
Default Lifts, Wheels, and Leveling Kits
I been going back and forth with some friends of mine on this subject and wanted to know what your opinions are on what brands and what set ups you think are the best. I'm talking about tire size on stock and after market rims, after market rims, lift kit height and brand, and leveling kits. some people say put a leveling kit on my 6.0, go with 35x12.50 tires on my stock rims, and dont go over a 4" suspension lift. i personally like big tall trucks but i also dont want the height to be a problem. i'm thinking a 6" lift and i can still pull a gooseneck trailer? if you have pics of your lifted truck, post it! i'd like to see whats out there without having to "just google it".
Old May 20, 2011 | 09:51 AM
Mdub707's Avatar
I don't think you're going to be pulling goosenecks with a 6" lift and 37" tires... which is what size most use on that lift. I run a leveling kit in front, F350 blocks in rear, and 315/70/17 BFG A/T's Had to step up to an 8" drop hitch already for my camper. The 6" I had worked, but it was slightly nose high, which is dangerous. If you're towing heavy and towing often, I would do the same, forget the lift. It can be done, but what's the point.
What's your budget and what do you use the truck for, those should have been my first two questions.
Old May 20, 2011 | 11:51 AM
spelt22000's Avatar
Madcreek!!
I was on the same path that you are going down now (lift looks bad a$$ on these) but, when i started to think about all the places i wouldnt be able to go anymore (i.e. parking garages, my own garage) also having problems hooking up to my trailers, i had second thoughts and now decided to keep it stock. Not to mention the lifts are through the roof if u do it right and if it's not done right then you end up with a whole lot of additional issues..
Old May 20, 2011 | 11:52 AM
Diesel_Daddy6.0's Avatar
I'm running a full 6" up front and 6" blocks out back with 18" rims wrapped with 35/12.50 Nittos. I would not recommend this setup for a bed-pull trailer, I backed under my dad's gooseneck and with the hitch an inch or so above the bed to judge for the hitch I only had about 2" of daylight between the trailer and my bed rails which would drop to about -1 1/2" cresting onto the highway from his road (his truck is stock height and he tagged the bed pulling off his road)Name:  l.jpg
Old May 20, 2011 | 08:42 PM
I use the truck for a daily driver and I'll be hauling cows with a gooseneck stock trailer. As for budget, I guess whatever an affordable set up would cost. I have no clue how much that would be. A friend suggested just go with a leveling kit in the front and I could put up to 35" x 12.50 tires on my stock 18" rims and they would fit and look good. Also, when the tire calls out the width, is that measurement across the tread or the overall width (sidewall too)? What consists of a leveling kit and could I machine one in our shop?
Old May 21, 2011 | 06:25 PM
Mdub707's Avatar
I wouldn't go much bigger than that towing a gooser. That setup will look good though. Yes you can machine your own, that's what I did, but they're only about $25 on ebay too... Ford F250 F350 4WD Leveling Lift kit 2005-2010 2.5" | eBay
I believe the 12.5 width is the tire width, not the tread, actual tread width depends on the wheel you put them on. I'm running that exact setup, except 17" wheels.
Tires will be the biggest cost for this setup, obviously.
Old May 26, 2011 | 07:48 PM
ph363's Avatar
I am looking to go with a similar set up. Anyone have pics?
Old May 30, 2011 | 06:19 PM
Wince's Avatar
I did a two inch lift myself for under 100 buck and less than an hours time. I added two inch blocks under the spring pads in the front. 2" lift blocks and longer u bolts in the rear. I made the front blocks from 2" bar stock. Drilled a 5/8" hole in the center. You need 2 10.9 x 100mm replacement bolts. You need at least a grade 5 bolt. I did the whole lift for $97 buck in parts and had it done in about an hour. It wont change your alignment much but it may change you steering wheels center. No big deal to loosen the adjustment sleeve and center the wheel. It wont hurt to check the alignment since it does slighty affect the castor angle. If I could figure out how to post a picture I would show you all some pics. I saw the same lift kit on Ebay and I figured I could make it as easy and not have to buy one.
Old May 31, 2011 | 07:15 AM
Mdub707's Avatar
Made mine too. Made mine just like the ebay link though out of billet aluminum, even chamfered it. Then swapped my stock F250 blocks from the back for a set of stock OEM F350 blocks. Didn't pay a dime for any of it!
I will wash the truck up today (finally some nice weather out this way) and get some pics of it with the leveling kit and the bigger tires.
Old Jun 1, 2011 | 08:24 PM
Mdub707's Avatar
Ok finally got a good side shot of it now.
FR: 2.5" billet coil spacer (DKM custom <-- ME)
RR: F350 OEM rear blocks
Tires: 315/70/17 BFG A/T's on OEM 17x7" wheels.
More pics here: https://www.dieselbombers.com/show-t...tml#post759756
