2006 5.9 cummins fuel preasure problems
I posted a thread about a week ago With a trouble code I could not figure out P0148 fuel delivery error. Well I think we finally found the problem. And I can tell you I will never replace injectors in a 3rd generation diesel again without replacing the fuel injector connecting tubes as well. The truck would start and run fine. I let it idle for an hour and it would not set the code but as soon as you hit the road and loaded the engine the code would set. I just installed new tubes and test drove it and it appears to be fixed. If it is not I will be sure to report it. Thanks for all the help Diesel Bombers.
Sometimes I wonder if they get damaged during the process or if there is a flaw that prevents them from otherwise sealing correctly...mine are original and have been in and out no less than four times, and they are still going 100k later.
RatsMC
May 4, 2015 05:25 PM
