Truck having a really hard time starting
Old May 19, 2011 | 08:12 PM
powerstroke7's Avatar
Default Truck having a really hard time starting
It got down to 43 degrees a couple nights and the truck didnt want to start took forever, but when its warm it is fine, I am wondering if the glow plugs are bad becasue once it starts up runs perfect. What are your guys thoughts?
Old May 19, 2011 | 09:00 PM
Mdub707's Avatar
Do a FICM test. It's easy and quick. Just google search 6.0 FICM test and repair. How are your batteries?
Old May 20, 2011 | 09:16 AM
I checked the FICM it tested fine and I plugged it in last night and it fired right up with no hesitation at all this morning.
Old May 20, 2011 | 10:19 AM
Mdub707's Avatar
Sounds like glow plugs then. I believe there is a way to test them with a multi-meter, let me see what I can find for you.
Found this:
There are 2 jumper harnesses that run down the side of each cyl head and connect to the main engine harness, dis-connect the connector and check resistance the resistance should be between 1 and 2 ohms
I'll keep looking and see what else I can find.
EDIT*
Attached "hardstart" PDF from Ford... walks you through testing on hard starts.
With that said, glowplugs almost never go bad on these.
File Type: pdf
doublehbar
13
Aug 9, 2015 12:35 AM
dfish001
Mar 30, 2015 03:07 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
SixSpeed
Jan 11, 2015 01:41 AM
Oct 14, 2014 08:40 AM
