found the problem/no fuel to injectors
Old May 19, 2011 | 04:34 AM
jwyeater's Avatar
Default found the problem/no fuel to injectors
FINALLY!!!! I had the problem of no fuel to injectors after replacing head gasket. While I had intake off, I replaced the fuel line from filter to IP. I found after taking intake off again, that I made new feul line too long. When I bolted filter housing to intake, the new fuel line kinked due to being too long. Of course, you can't see fuel line after intake is installed. I cut about an inch off of line, bolted everything back together, cranked engine a few times and began seeing fuel at injectors. I tightened down the lines, turned it over a few more times and it started right up. Idles smoooooth!! Haven't got to test drive yet, I will in a few. I want to THANK everyone who helped out. I have learned alot. I still have many questions about performance and power and will be checking in. THANKS AGAIN!!!
Dbleo351
Nov 20, 2016 09:34 AM
garyspruyt
Aug 28, 2015 03:14 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
