6.5 Starting Problems
Old May 18, 2011 | 10:13 PM
3408CAT's Avatar
Default 6.5 Starting Problems
Hey Guys Im new here But I have A question for you guys. I have a 94 6.5 that I bought not running So first off I put two new batterys in it and could hear the fuel pump run so I went to turn it over and nothing it just turns over and dosent fire. Well we changed the injector pump and still no go its getting fuel to the injectors but it just wonts start. It wont even run on ether so tell me what you guys think it could be. Two of the glow plugs are broke off but i figured it should still run on ether but it dosent. Thanks Cody
Old May 19, 2011 | 04:57 AM
jwyeater's Avatar
Default starting problem
I'm no expert, but have some experience with 6.5td. First off using starting fluid is not a good thing. It will cause severe damage. If your getting fuel to injectors, allowing injectors are good, glow plug system needs to be checked out. IF you are getting fuel into cylinders, low compression could be a problem. Is engine turning over fast enough? Is fuel good? IP timing good? Air in supply line? Remember the basics: 1)Timing 2)Compression 3)Fuel 4)Air. You can pull the glow plugs and have someone turn the engine over, check to see if there is a mist coming from glow plug holes, that will tell you if fuel is getting past injectors.
Old May 22, 2011 | 12:31 AM
Woody35's Avatar
did you time the pump with a scanner when you replaced it?
Old May 22, 2011 | 03:25 AM
smokee44's Avatar
I have 6.5 turbo and after warms up and driven,I turn it off it wont start intil it is completely cold and starts and runs like new
if you can help me I would really a perseate it
Old May 22, 2011 | 06:50 PM
pipelayer4777's Avatar
Check your PMD smokee. are thre any codes?
Old May 23, 2011 | 11:20 AM
Crazy's Avatar
Hey 3408Cat
make sure your Crank Position Sensor not bad or broken
Old May 23, 2011 | 02:29 PM
munger59's Avatar
And howse supposed to do that
Dbleo351
Nov 20, 2016 09:34 AM
Easton18t
Jul 30, 2015 02:06 PM
petew
Jul 25, 2015 03:56 PM
Chevy6.5/2500hd
Jun 1, 2015 09:44 AM
angies04
Sep 29, 2014 04:11 PM
