special tool for tightening injectors?
Old May 17, 2011 | 10:57 PM
jpfiero's Avatar
Default special tool for tightening injectors?
Anyone figured out a way to tighten the retaining nut without removing the lines?
About a week ago my #2 retaining nut loosened off and the injector was actually "hopping" on every compression stroke, I managed to get that one tight again with a small crescent wrench but now my #6 injector is oozing diesel around the retaining nut.
Also my #4 injector is always "moist" just under the pressure line nut, any ideas how to get it to seal? I don't want to tighten it any more I'm afraid I'll break something
Thanks
Old May 18, 2011 | 12:18 AM
rallyit67's Avatar
You can't get enough movement out of the line if you unhook it? I would just undo the line(s) and torque the nut(s) back down. I think the spec is 42 pounds??? It won't take much cranking to bleed the air out and you should be good to go.
Old May 18, 2011 | 03:37 AM
H.R.D's Avatar
Thanks
Does it have an O ring on it? If so you may need to replace the O ring.
Old May 18, 2011 | 10:05 AM
rallyit67's Avatar
I am pretty sure the O-ring is just a dust seal. It doesn't seal off the injector and you don't need them. A lot of ppl just put a lil grease where the O-ring used to go because they always break and wear out.
Old May 18, 2011 | 10:59 AM
daveO's Avatar
The injectors have a copper sealing washer where they seat into the heads. Sometimes, if you're putting injectors in and knock a little bit of carbon or something down in there, it will almost never seal up no matter how much you torque them.
Old May 18, 2011 | 11:27 AM
jpfiero's Avatar
I had the head off and cleaned the injector bores really well before installing the injectors, I also used all new cummins brand copper washers. I don't have dust washers that sit on top of the injector retaining nut, but I did use anti-seize on the threads and injector body. I guess I'll try and remove the lines and retourque the nuts.
Is there a torque spec for the pressure line?
Thanks
Old May 18, 2011 | 12:59 PM
daveO's Avatar
The 98 FSM calls for 18 ft-lbs for the high pressure lines.
Old May 18, 2011 | 01:32 PM
jpfiero's Avatar
ok thanks
Old May 18, 2011 | 01:45 PM
H.R.D's Avatar
They are they for a reason my friend, I would make sure they are there and in good shape. But that is just me.
Old May 18, 2011 | 02:16 PM
jpfiero's Avatar
I would have replaced them but the complete gasket set i got from cummins didn't come with any and I didn't have time to drive back. Not sure why they don't include the dust rings when absolutely everything is is included.
carid
Diesel Bombers Sponsors
Sep 19, 2015 07:21 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
