12v Fuel Pressure Test Fittings List
Old Dec 18, 2007 | 12:50 PM
johntf's Avatar
Default 12v Fuel Pressure Test Fittings List
My search abilities do not seem to work , I was going to help some one with there truck , and want a list if fittings & numbers / link , for fuel pressure test , shrader valve , needle valve ??
Thanks John
Old Dec 18, 2007 | 09:13 PM
sawmillman's Avatar
I just drilled and tapped the banjo bolt goning into the injection pump then you can use what you want.
Old Dec 18, 2007 | 11:22 PM
What sawmillman said. Remove the inlet banjo bolt on the P-7100. Drill and tap it 1/8" NPT, install a 1.8" needle valve, run the tubing to your guage in the cab. Couldnt be easier - and it should look something like this: Name:  25501mvc-016f.jpg
Old Jul 15, 2008 | 10:46 AM
John, did you manage to get this figured out?
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
vfizzano
17
Oct 9, 2014 02:26 PM
