need advice for my 01 3500 24 v
Old May 17, 2011 | 05:12 PM
2001oldGREENhun's Avatar
Default need advice for my 01 3500 24 v
IM wanting to put a banks intake, an edge juiced with attitude some injectors bigger turbo But dont know wat size or brand with the injectors and turbo
Old May 17, 2011 | 06:31 PM
01cummins13's Avatar
first you need a Air Dog, Raptor or Fass fuel system to keep the VP44 happy, the edge juice with attitude will cover your gauges. As far as injectors and a turbo goes it depends on what you plan on using the truck for. There are lots of great guys here that will help you with that info. good luck on your build buddy!
Old May 17, 2011 | 08:05 PM
im wanting to be able to puul heavy loads with ease but dont want to go so big that i half to change fuel lines as for the turbo i want to keep it single ang not so big that i will half to worry about burning something up as far as studing the heads i could do that
Old May 17, 2011 | 08:51 PM
well like i said before it all starts with a lift pump, such as an Air Dog, Fass or Raptor. you will need the fuel to keep the VP happy, and to keep up with the juice and injectors, the stock lift pump just wont cut it at all
Old May 17, 2011 | 10:51 PM
D-LUX's Avatar
search... your askin a pretty broad question with no background on your truck..
there is alot of great info on here, look at other people's set up and see what ya like..
id like to help but im not going to spoon feed it to ya
Old May 18, 2011 | 10:54 PM
Mr.Krabs's Avatar
Need fuel first,if that's more than you want to take on then I'd sell it and buy something newer with more power.
Second Gen trucks are great,after you fix the things that should have been done right from the start,put a fuel pressure gauge on it,or it will cost you a $1200 injection pump.
Old May 18, 2011 | 11:48 PM
H.R.D's Avatar
Like stated above lift pump is number one. For injectors I would stay in the 100 to 150 hp range and for a good turbo a s300 should do you good. But you need to search around and see what other people have to say about their setups. Good luck to you and welcome to DB.
Old May 19, 2011 | 12:58 AM
hydroshok's Avatar
If you just want to haul with it don't waste your money on injectors or a turbo until they need replaced. I have an 07 with stock turbo, all the mods in my sig and it pulls great. How many miles on your truck? I realize the 07 has more power, but depending on what you want to haul you might be fine. I'd suggest you let the truck breathe first with an intake, exhaust and gages (get the edge for the gages if thats what you want). I can let you know how well the 99 pulls when I get it on the road if you want. Like everyone else said get an upgraded lift pump first. I put the fuel pressure gage on the 99 and it is barely getting 5psi going down the road with the stock set-up. It is not hard to install and will save you money and fuel in the long run.
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
Jun 22, 2015 12:40 PM
twm011
Feb 24, 2015 09:11 AM
DIESELDENT
For Sale
Dec 19, 2014 06:53 PM
