Throttle Valve
Old May 17, 2011 | 04:55 PM
kieron_kohlmann's Avatar
Default Throttle Valve
Does anyone know how to adjust the throttle valve on the valve body? I removed the set screw and now im not sure how far it should be screwed in.
Old May 17, 2011 | 05:10 PM
tower_ofpower's Avatar
what screw are you turning in? are you talking about the screw that adjust spring tension on the side of the valve body? you're supposed to screw it in until the little piece of metal sits just flush against the cage. but i thought the only adjustment for the throttle valve was by lifting a clip and moving the cable (adjusting distance until the throttle valve cable was activated)
Old May 17, 2011 | 09:19 PM
No its called a throttle valve. it has a allen bolt head. its not the one that sits flush.
Old May 18, 2011 | 02:57 AM
Hmmm just got done doing a shift reprogram kit and I don't recall anything of the sort. Pics?
Old May 24, 2011 | 01:30 PM
Where the pick is pointed.
Old May 24, 2011 | 01:56 PM
Ahhh I see, no clue... The shift kit I got told me not to touch it.
Old May 24, 2011 | 06:38 PM
Yeah the shift kit I got didnt say to touch it, but i did.
Old May 24, 2011 | 08:22 PM
Hahaha live and learn. Find a trans shop and ask them
RA113024
Mar 13, 2016 07:42 PM
Andyhc1
Mar 16, 2015 12:00 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
1stgenswap
Nov 3, 2014 09:45 PM
