How hard is a auto to manual swap and what is the avergage cost?
Old May 15, 2011 | 06:28 PM
7.3 Cowboy's Avatar
Default How hard is a auto to manual swap and what is the avergage cost?
I recently sold my stroker and i am jumping ships you can say and am lookin at a 12v or 24 v cummins but i can not find any truck that are set up how i want but i can find automatics just like i want. SO i am wanting know how big of a deal is it to put a manual in one. We did a swap on a buddies 1/2ton chevy and had a donor truck and everthing bolts right up will it be that easy on one of these truckS?
Old May 16, 2011 | 12:59 PM
7.3 Cowboy's Avatar
Default Re: How hard is a auto to manual swap and what is the avergage cost?
No one has any input?
Sent from my DROIDX using Tapatalk
Old May 16, 2011 | 05:03 PM
12vcummins96's Avatar
its the same its all bolt up just cost alot is all and time consuming
Old May 16, 2011 | 07:21 PM
monster12valve's Avatar
it will all bolt up except you are going to have to swap the input shaft on the transfercase. there is complete kits for $3500 with everything even a 450hp clutch. but u can piece it together for cheaper if you hit ebay or craigslist. its not a hard swap if u take your time. p.s dont use an nv4500 out of a gas truck. and dont swap the trans output shaft to the smaller one.... swap the t=case to the larger splined shaft.
