lift pump?
Old May 15, 2011 | 04:51 PM
lauber_03's Avatar
Default lift pump?
i put a bd low fp indicator on my truck and when its not running the light is on, i have the fuse tapper ran into my horn fuse. lift pump bad or wrong place to wire it into?
Old May 15, 2011 | 06:38 PM
kerley's Avatar
You need to go to your fuse box. There are vacant fues holes that you can use. Find one that is only energized when the ignition key is ON.
Old May 15, 2011 | 06:50 PM
lauber_03's Avatar
the box under the hood or the one inside the door jar?
Old May 15, 2011 | 08:12 PM
turbo20psi's Avatar
The one on the inside (drivers side) with the door opened.
Old May 15, 2011 | 08:20 PM
lauber_03's Avatar
oh ok any suggestion to which fuse then
Old May 16, 2011 | 05:47 PM
kerley's Avatar
Default Fuel Pressure
If you will read all past posts on Fuel Pressure /Supply or LP/ vp44, you will learn everything about your Dodge/Cummins system.
Good Luck
Old May 16, 2011 | 06:31 PM
lauber_03's Avatar
yeah i read into them last night, i ran it into the windshield wiper fuse. also found out when i hit about 2200 rpms its comes on so i had a friend come over with his fuel psi tester and it was weak. time for a airdog
HeavyChevy95
Dec 21, 2016 10:36 PM
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
