timing bump
Old May 14, 2011 | 11:35 PM
lodal cummins's Avatar
Default timing bump
how many degrees does the 1/8 timing bump set you at 14.5 or 15? thanks alot!!!!!!
Old May 16, 2011 | 04:21 PM
cougar's Avatar
Sat down and figured this out one day. And with a little help from some friends, got the numbers fine tuned.
Cummins engine VE pump timing: (unverified)
1.25mm pump lift = 12.5° stock intercooled (1.4mm stock non intercooled)
2.4mm additional pump lift (advance) = 21° - 22°
M&H timing spacer increases to 6.4mm advance = 31° - 32°
1mm pump rotation = 1° timing (verified)
1 tooth on drive gear = 5° timing (verified)
1/8" bump is 4° - 5°
Hope this helps
Old May 16, 2011 | 06:57 PM
so is it safe to say after 12.5 stock the 1/8 gets u around 14? thanks for taking the time to verify this. what is the M2 timing spacer?
Old May 17, 2011 | 10:06 AM
cougar's Avatar
1/8" bump puts you at a 16ish-17ish base timing.
The M2 is a fuel pin.
The M&H Dynamic timing device (timing spacer) allows for more total advance. 12.5° to 32°, instead of the stock 12.5° to 22°.
Old May 17, 2011 | 03:06 PM
901stgen's Avatar
So by looking at your math that would put a non-intercooled engine at around 13°? Correct?
Old May 17, 2011 | 04:33 PM
so if the 1/8 puts you around 16 17ish are we risking a head gasket?
Old May 17, 2011 | 09:09 PM
cougar's Avatar
Yes, around 13°-14°.
No, quite a few people bump it a lot more and/or jump the gear a tooth. How ever, when you advance the timing you take away from the low RPM end to give to the high RPM end. Your modifications, tuning, and end purpose will determine your best timing. For example, my 91 had the gear jumped a tooth but did not perform as well as I would have liked when towing. So now my base timing is back to stock plus the timing spacer. That gave me my low end back and extended my upper end.
Old May 18, 2011 | 04:15 AM
901stgen's Avatar
Where's a mod? This needs to be a sticky......
Old May 18, 2011 | 09:01 AM
BC847's Avatar
Hope this helps
Crap!
I've got my mess advanced two teeth, with the pump set just a hair past the stock marks. Plus the M&H spacer.
Still tweaking it though.
Old May 18, 2011 | 02:51 PM
cougar's Avatar
Originally Posted by BC847
Crap!
Yes, but your special.
