OS filter
Old May 14, 2011 | 10:04 AM
seldy's Avatar
Default OS filter
It's probably a no brainer but I don't know what a OS filter is or where it's at. Thanks
Old May 14, 2011 | 04:43 PM
jwyeater's Avatar
Default no fuel
Since we are having the same issues with trucks, I thought this might help. I couldn't get fuel to injectors. We removed the intake and loosened fuel line to IP. After getting fuel there,I opened injector lines at the IP and after a few minutes, got fuel there also. Then opened lines at the injectors and after a few minutes of crankin, got fuel there. Closed everything up and the truck fired and ran for a few. Put the intake back on and now won't start. I don't know if that helps. If you find out something, let me know. I'm going to remove intake again and start over. Maybe fuel line is collapsing.
Old May 14, 2011 | 05:51 PM
Crazy's Avatar
you will fine it plug in to top of the IP just unplug at both ends and plug the wire harness back in to the IP take 5mins do that
Old May 15, 2011 | 12:27 PM
seldy's Avatar
Default No OS filter
Thanks Crazy, I checked and found no plug as your pictures show. I don't believe it has ever been on my truck as I am the only owner unless the dealer removed it years ago when they replaced one of the bad injector pumps. Could the crank sensor have any impact on my problem?
gone ropin
17
Dec 3, 2017 06:31 AM
jeffersonl
Nov 15, 2015 07:35 PM
Bob V
Apr 6, 2015 11:02 PM
jeffersonl
Oct 25, 2014 06:46 AM
james2562
Oct 8, 2014 06:14 PM
