problems with front axle camber
Old May 13, 2011 | 11:32 AM
tony01's Avatar
Default problems with front axle camber
So the other day i went to get my truck aligned n they said that my lower control arm caster camber brackets are brokenand its the horse shoe pieces on the axle itself and was wondering if any body knew where to find some or would i have to go and get them from a junk yard or something? any advice would be help full btw it a 01 one ton 4x4
Old May 14, 2011 | 12:05 AM
tworks's Avatar
i have just tack welded the hourseshoe pieces back onto the diff bracket. Chances are that the bolts going through the bracket are siezed and they pulled too hard to adjust. (been there done that ) install ajustable ball joints instead or have the sieized bolt replaced. Good luck
Old May 14, 2011 | 11:58 AM
tony01's Avatar
The problem is i don't know where the rest of the horse shoe pieces r at or where to get some at
Old May 14, 2011 | 12:42 PM
tworks's Avatar
find a autowrecker that has a totaled out front diff (no good to them for resale) and ask if they would cut the bracket off for you. You can then zip cut/grind off welds and use just the horseshoe shaped piece and have it welded back in place.
Old May 17, 2011 | 11:05 AM
1AMatt's Avatar
Site Sponsor - 1aauto
These are part of the axle so i dont believe anyone will have the for sale.... Check with the dealer. I believe you will have to get them off of a junk axle like tworks said!
jones
Feb 24, 2015 02:55 PM
Natenelson1
Jan 19, 2015 07:23 PM
KYLEBOY
Jan 18, 2015 06:36 PM
Cumminsman911
9
Nov 1, 2014 04:07 PM
natenel1
Oct 26, 2014 03:09 AM
