NEED HELP !! NO FUEL FROM INJECTION PUMP
Old May 12, 2011 | 09:49 PM
jwyeater's Avatar
Default NEED HELP !! NO FUEL FROM INJECTION PUMP
I have a 93 gmc 3500 6.5 turbo, was running fine. Parked to replace head gasket, all went back together good. Can't get to start. No fuel from IP. Have Mechanical pump. Have fuel to filter. I can hear LP operating. Checked power to F/SOL with test light,OK. What else could stop pump from pumping fuel to injectors?
Old May 12, 2011 | 10:46 PM
chummins89's Avatar
My guess would be the solenoid isn't operating , even though it has power.
Old May 12, 2011 | 11:22 PM
Crazy's Avatar
not sure on 93 but check make sure OPS working right
Old May 13, 2011 | 09:03 AM
jwyeater's Avatar
Thanks for the reply, but I'm just learning and not sure what ops is, or what to do about it. I think I have located the solenoid. I guess my next step is to take the injection pump apart. Not sure, but I have to do something. Any further info would be greatly appreciated. Thanks again
Old May 13, 2011 | 11:34 AM
Crazy's Avatar
pull the fuel line off at the IP see if have fuel there maybe have clog between the filter and IP
Old May 13, 2011 | 01:27 PM
jwyeater's Avatar
Default no fuel
Thanks for info. I replaced fuel line between filter and IP, no clogs. And, my LP is wired direct, bypassing ops. I checked solenoid and hear click when energized. That should indicate it is opening, correct? Will not even fire with starting fluid ( wd-40 )
Old May 13, 2011 | 03:16 PM
Crazy's Avatar
do not used starting fluid you won't have motor for long
do you still have the OS fliter if so try remove it and see if it would start
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
nelly559
Feb 17, 2015 06:49 PM
moneypitk5
Feb 12, 2015 11:01 AM
