2006 5.9 cummins
Old May 11, 2011 | 09:03 PM
Billy Langston's Avatar
Default 2006 5.9 cummins
I have a trouble code I cant figure out P0148 fuel delivery error. I have recently installed the air dog fuel transfer pump. But I reconected the factory pump and it still sets the code. Can any one help.
Old May 11, 2011 | 09:17 PM
12vNick's Avatar
Do you have a programmer on the truck? Was it low on fuel? Did you run it outta fuel? Any fuel on the engine block around the injection lines?
P0148-HIGH PRESSURE COMMON RAIL (HPCR) CHECKSUM For a complete wiring diagram Refer to Section 8W. [ul][*]When Monitored: While the engine is running.[*]Set Condition: A deviation between the fuel pressure set point and the actual fuel pressure.[/ul] Possible Causes OTHERS DTC'S PRESENT-- FUEL LEAKS-- FUEL CONTROL ACTUATOR-- FUEL PRESSURE SENSOR--- CASCADE OVERFLOW VALVE--- CHECK VALVE DAMAGED OR BLOCKED--- FUEL RETURN LINES OBSTRUCTION, DAMAGE, OR DEBRIS--- LIFT PUMP FLOW--- AIR IN FUEL SYSTEM--- LEAKING FUEL INJECTORS OR HIGH PRESSURE CONNECTORS--- PRESSURE LIMITING VALVE--- HIGH PRESSURE FUEL PUMP
Old May 11, 2011 | 09:49 PM
Farmboy 2.0's Avatar
How does the truck idle? Does in run rough or miss?
Old May 11, 2011 | 10:17 PM
I have also just replaced the fuel injectors and was wondering if the fuel cross over tubes could be leaking and causing the code but if they were leaking I thought it would be hard to start. There are no symptoms just the code. I have cleared it repeatedly trying different things. but it still sets the code.
Old May 12, 2011 | 09:27 AM
The crossover tubes could cause this as well, but as you said it should hard start unless it is a minute amount
Old May 12, 2011 | 09:37 AM
Does anyone know where I can find a mechanical fuel pressure test kit for this 2006 5.9L Cummins?
Blake35
Jan 30, 2016 11:29 PM
jmont61
Potential Diesel Owners Forum
Jan 22, 2016 07:29 PM
nathanmueller
Diesel Engine Conversions
Sep 8, 2015 03:30 PM
Sbboozer
Nov 16, 2014 05:52 PM
78F250Cummins
Wanted To Buy (WTB) - Used
Nov 9, 2014 01:12 AM
