24 vavle lift pump work on 12 vavle
Old May 11, 2011 | 08:45 PM
justajunk12vavle's Avatar
Default 24 vavle lift pump work on 12 vavle
i was told today that a lift pump from a 24 vavle wood work somehow on a 12 vavle and they siad it be pretty much like a mini fass system..this true or is this guy blowin smoke
Old May 12, 2011 | 08:51 AM
12vNick's Avatar
I dont know if it is true or not but the lift pump on 12vs are pretty good i know a couple of guys holding 700 hp on the factory 12v lift pump.
Old May 12, 2011 | 11:03 AM
94 12valve's Avatar
if you run just the 24v lift your truck would run but it will not have the right fuel press for the p pump, the vp's required supply press is too low for a p pump. I don't see why you couldent use it as a pusher pump to feed the stock lift pump tho.
Old May 12, 2011 | 05:21 PM
kieron_kohlmann's Avatar
Theres a thread in the first gen sticky on how to make it work. Nevermind. 24to12 not what i was thinking of 2nd to first gen.
Old May 13, 2011 | 05:49 AM
BRE's Avatar
BRE
No you dont want to run the 24v pump as a single I would and I personally am doing this shortly going to run a 24v pump to push my stock 12v pump.
Old May 13, 2011 | 10:21 AM
12vcummins96's Avatar
no
Old May 13, 2011 | 02:04 PM
Hightech_Redneck's Avatar
i wouldnt do it personally... if you put 15psi fuel pressure to a p-pump you will be hurting it instead of letting it feed itself... just like dave i would say to maybe use it as a pusher if your getting it cheap enough but you must remember that the main reason why a vp pump goes out is cause of their junk lift pumps... IMHO save the money and eventally get an AirDog 150 or 165 ADII with the adjustable fuel pressure... try running around 40psi fuel pressure...
the good ratio i have seen is 100 rpm to 1psi fuel pressure
IE 4000rpm you want 40psi
landon025
Sep 8, 2015 09:21 PM
ctjkelley
Jun 3, 2015 06:01 AM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
