EGT??
Old May 10, 2011 | 11:27 PM
legs8803's Avatar
Default EGT??
I see everyone talking about the egt. What should the temp run on a 6.0?? what is considered high??
Is there any programers that have a egt gauge built into them?
Old May 11, 2011 | 03:10 AM
Diesel_Daddy6.0's Avatar
I'm not sure on the temps, but as far as the guage, a lot of modules, even the "fuel economy coach" BullyDog Watchdog has one, but you still need to buy and install the EGT probe behind the turbo.
Old May 11, 2011 | 07:35 AM
Mdub707's Avatar
If you're running stock you basically can't get it hot enough to even worry about. Safe temps for extended periods are 1250 or less. Short bursts like a sled pull or a drag race, it can go higher.
Think of it like putting your hand in an oven at 450. You put your hand in for a quick second and pull it out and it's ok. Hold it in there for 30 seconds and see how hot it gets.
I know some guys get close to 1800* on a drag race or sled pull. If you're getting that hot you may want some water to add to the mix. I've maxed my 1600* gauge a couple times. I try to keep the heat real low now though so I don't have to do headgaskets again. Heat is bad obviously, so just use common sense. When I tow, I try not to go over 1100 at all, but the magic number you'll see on the boards is 1250 or less.
kevin krehel
18
May 14, 2015 05:07 PM
TurboBoy6.5
Apr 12, 2015 11:22 PM
Brappp306
Mar 29, 2015 08:54 PM
MrCat4974
Mar 23, 2015 11:30 PM
offroad00
24
Oct 23, 2014 03:28 PM
