Dmax problems!
Old May 10, 2011 | 03:19 PM
smokincummins92's Avatar
Default Dmax problems!
Hey guys. I am having problems with an 02 2500 chevy with the Dmax. Its all stock as far as I know. It came to the shop smoking like a freight train and skipping. It would smoke bad at idle but the more rpm I gave it the worse it got! I checked the balance rate and the injectors were shot! So I replaced them and droped the tank and draind all the old fuel out and flushed all the fuel lines and replaced the fuel filter with a new one. Got the truck started yesterday.....still smokes and has a skip It dosnt smoke as bad as it did before I replaced the injectors and it seems to be runing better but it still seems to have a skip and it still smokes some at idle and as I give it more rpm it gets worse! I have checked all my connections to see if one is loose somewhere but all seems fine. My computer (AUTO ENGINUITY) want give me any live data at all which leads me to thank a connection problem....but it will do some diagnostics such as glow plug curcuit and a few things. But when it does a diagnostic on other things like trans and engine codes it comes back saying lost communication or ecu malfunction....do I need to replace the ecu on this thing? Are they known for going bad? What about the Injector driver module? Anything that will help will be GREATLY appreciated!!!!!!!!!!!!!
Old May 14, 2011 | 06:13 PM
Anyone??????
Old May 25, 2011 | 03:00 PM
Natedawg!'s Avatar
what colors the smoke?
Old May 26, 2011 | 02:05 AM
BRE's Avatar
BRE
Injectors?
Old May 27, 2011 | 11:27 AM
[QUOTE=Natedawg!;757416]what colors the smoke?[/QUOT
Light black color and I have already replaced the injectors
Old May 27, 2011 | 03:21 PM
Natedawg!'s Avatar
Head gasket maybe? I would think if it was a head gasket tho it would be white
BubbaDT55
Apr 12, 2015 10:47 PM
moroza
Mar 29, 2015 05:37 PM
ChevyGuyForLife
Chevy/GMC Duramax 06-07 LBZ
Jan 13, 2015 12:29 PM
JRB1960
Dec 1, 2014 09:24 PM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
