fuelplate Mod
Old May 9, 2011 | 02:52 AM
alexbland's Avatar
Default fuelplate Mod
Hey, i was reading on the fuelplate mod and i was woundering if i should do it with the stock transmission. Its got 120k on the tranny and motor. no shifting problems (auto) i dont rev the motor over 2.1k rpm's.
also off topic, when i bought the truck the guy told me the rear end it has in it ratio was 4.11:1 or something like that. I know there is a lower ratio rear end i was woundering if it would be smarter to change it out?
Old May 10, 2011 | 09:21 PM
PowerstrokeConvert08's Avatar
to question 1: in a word: No. these trannies dont hold stock power, much less anymore you throw at it...most I would do is slid the stock plate forward. In the end its all how smart you are, I met a guy with and Edge juice, sticks,. intake and exhaust on a stocker for 40 k...I dont know how, guess he just curled his toes in his boot to accelerate...
number 2: they came with two choices, 3.55 and 4.11, if you pop the hood and look up there should be a model tag that tells all the options on the truck. depends if you do more city or more highway driving as to the wisdom in changing gears...personally I would bump the tire size up to 33s or so to get cruising rpms down, but you'd still have the get up and go of 4.11s. Ive got a buddy that runs a 4wd auto with 4:11s, he has 17s on 285/65s. runs about 1900-2000 rpm at 70 on the highway.
Old May 16, 2011 | 07:27 PM
monster12valve's Avatar
x2 you can pull the plate but be prepared to have trans issues. mine slips at 10psi and up when the tc is locked
coal_life
Aug 26, 2015 07:50 PM
