Timing failure
Old May 8, 2011 | 08:59 PM
CumminsKid6's Avatar
Default Timing failure
Did my timing. Thought I put it at 17*. But it white smokes alot and and breaks up real bad. How far do u think I actually went. And or did I and that's just cause it's cold and and needs to warm up
Old May 9, 2011 | 01:57 AM
BRE's Avatar
BRE
No it sound to me that you either dont have the right plunger lift setting and set it wrong or it slipped when you started it. The things your stating are dead give aways of retarded timing.
Re time it and make sure the pump shaft is good and clean prior to re-seating the gear.
Old May 9, 2011 | 08:47 AM
So to make sure I get this right I wanna spin the motor counter clock wise to advance my timing. Correct??
Old May 9, 2011 | 09:23 AM
12vcummins96's Avatar
Here you go bud
TSB 18-10-94 Rev. A
Old May 10, 2011 | 01:49 AM
Today was a success and got it right but it's got a rattle. Think it's cause I forgot to put a load on the gear. And it makes a rattle sound type noise to it. Gonna fix it tomorrow and hope that takes care of the. But other wise really impressed with power out put for stock dv's and injectors. Now I need a clutch for sure stocker doesn't take to kindly to the new found power
Old May 10, 2011 | 02:37 AM
BRE's Avatar
BRE
That rattle your most likely hearing is a slight timing rattle. Which will sound huge to someone who has never heard it or is going from stock timing is def. going to notice it.
Old May 10, 2011 | 12:09 PM
Well it's really loud. U can hear it over top of my 5 to 8 inch exhaust. It goes away when it's up high and idling. But mid range it's loud
Is there anything I can do to make it quieter. Just noises on my truck make me paranoid. I know it's all right but its just something I hate
Last edited by CumminsKid6; May 10, 2011 at 12:09 PM. Reason: Automerged Doublepost
Old May 10, 2011 | 01:14 PM
94 12valve's Avatar
your sure the lines are tight and you put the DV's back in the right way
Old May 10, 2011 | 05:23 PM
madmikeismad's Avatar
How far did you advance it? 1/2 turn on the damper is 8* give or take.
And yes, counterclockwise to advance.
Old May 10, 2011 | 06:22 PM
94 12valve's Avatar
1/2 a turn on the damper is 180*
