How often do you actually adjust your bands?
Old May 7, 2011 | 06:14 PM
Gas's Avatar
Gas
Default How often do you actually adjust your bands?
I was thinking about doing a pan drop and filter change on my transmission just as good preventative maintenance. I always adjust transmission bands when I pull a pan but I haven't taken the pan off of an A518. Should I adjust them or leave them be?
Old May 7, 2011 | 06:51 PM
crewcab59's Avatar
I set mine when i pull the pan but vary rarely do they need it. of course i cant remember the procedure.
Old May 7, 2011 | 09:38 PM
Gas's Avatar
Gas
I'm not sure why I would even adjust them at the moment if I don't think it needs adjustment. Even the fluid looks clean regardless that they say ATF 4 color doesn't indicate condition - I call bull on that because a wearing transmission thats out of adjustment eats through friction material faster and has darker color fluid.
Old May 7, 2011 | 11:02 PM
SNOOT's Avatar
I do mine every winter when I drop the pan to clean it. 30+ 1/4 miles passes and 30K miles and still rocking.
Old May 8, 2011 | 09:15 AM
Gas's Avatar
Gas
Ok cool. How much fluid with a stock pan drop?
Old May 8, 2011 | 09:36 AM
tower_ofpower's Avatar
you're looking at atleast 8 quarts, all depends how long it drains. i had my VB out for a few days and installed an extra deep aftermarket pan... took 4 gallons + a quart to fill it back up
Old Jun 11, 2011 | 02:11 AM
jwirth's Avatar
(518 trans) front band adjustment. Loosen band adjusting screw locknut. Tighten band adjusting screw 72 IN lbs. If extension is used tighten to 47- 50 IN lbs. Then back off adjusting screw 2-1/2 turned. Hold adjuster screw in position. Then tighten lock nut 30ft lbs.
Same for rear only back off adjusting 2 turns. and tighten locknut to 25ft lbs. factory specs. for you opinionated people. I loosen mine 3 turns front band and 2-1/2 rear seems to shift better.
93cummins12v
Dec 22, 2014 11:06 PM
