power steering help?
Old May 7, 2011 | 09:24 AM
blue24valvecummins's Avatar
Default power steering help?
i noticed that my power steering was starting to get tough so i replaced the power steering pump and put new o rings and a seal in the vaccum pump. but it is still hard to steer i did the bleeding process like my chiltons manual says. it said to fill it up and start it and keep working it back and forth. any sugestions? i did flush out all the old black fluid. and i have no leaks
Old May 8, 2011 | 08:26 AM
Ed ke6bnl's Avatar
I do not know if you have a 4x4 or bigger tires like I do, but I can not turn the tires in some cases in a complete stopped position on my truck. Not the best thing when I have my pull travel trailer on the truck.
Old May 9, 2011 | 07:54 PM
94dizzyram's Avatar
most reman steering boxes are junk. I went through 4 before I finally broke down and bought a brand new psc.
Old May 9, 2011 | 08:13 PM
24vcumminscowboy's Avatar
did you have the front tires on the ground cause i know when i had to bleed my power steering i jacked up the front end so i could turn the wheels easier dont know if that helps at all but just thought id throw it out there
Old May 14, 2011 | 08:39 AM
well i found out what was wrong after replacing my power steering pump and my steering gear box and $250 later. come to find out it was a damn $40 steering stabilizer the stabilizer had locked up internally and when i took it off the pickup i couldn't get it to move, talk about frustrating.
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
krg3590
Mar 15, 2015 08:57 AM
1MooseheadPlease
Oct 13, 2014 05:33 AM
sweetv8s10
Oct 7, 2014 09:47 PM
