Shifting problem
Old May 6, 2011 | 02:38 PM
Dude_57's Avatar
Default Shifting problem
Ok so once again my truck I's downshifting every once in awhile. My truck used to have this problem really bad until I got the throttle cable replaced and the tps sensor adjusted and replaced and noe after months o it not doing it every once in awhile I'll be doing 50 or so while in overdrive and Ot will downshift..... Any ideas at all????? Thus I's getting old with this truck.... Lol any help would be great!!!! Thank you
Old May 6, 2011 | 08:16 PM
oil_burner's Avatar
tv cable needs adjusted maybe?
Old May 7, 2011 | 09:19 AM
lodal cummins's Avatar
clean the crank position sensor and see if that helps
Old May 7, 2011 | 04:11 PM
Dude_57's Avatar
If the throttle cable needs adjusting I'm afraid it might get un adjusted when I mash on it again I dunno much about all of it yet and crank position sensor?? Where I's that at?
Old May 7, 2011 | 06:28 PM
it is the sensor right above the harmonic balancer, pull it off and spray with break cleaner. might be oil or dust on it not getting good signal. regap at.040 or use credit card. real quick fix and worth a try!
Old May 9, 2011 | 02:30 PM
Dude_57's Avatar
After looking under the hood I found out that this little tps bar with the snap head on it I can move it up and down but won't come off it feels like it has alot of play I's this supposed to be like that? Or somewhat firm
Old May 11, 2011 | 02:10 PM
Dude_57's Avatar
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
SixSpeed
Jan 11, 2015 01:41 AM
Oct 14, 2014 03:30 PM
