02 24 v will not shift outta 4th gear
Old May 5, 2011 | 06:48 PM
s.butler982010's Avatar
Default 02 24 v will not shift outta 4th gear
hello everyone, i was getting on the interstae the other morning and i might have put the lock up switch on a little early..................the truck will shift 1-4th just fine but it will not shift into overdrive..............fully built automatic???? cant seem to find the problem i have un hooked the lock up switch but still does the same thing and also un hooked the battery to maybe clear the computer
any input is appreciated!!!!
could it be a solenoid?????
Last edited by s.butler982010; May 5, 2011 at 06:48 PM. Reason: Automerged Doublepost
Old May 5, 2011 | 07:58 PM
RAW's Avatar
RAW
It could be the T/C lock up solenoid. After my trans was rebuilt I can pretty much feel 5 shifts. 1-2-3-3 L/U-O/D.
Old May 5, 2011 | 08:11 PM
i will have to look into that where is that located...appricate everything
under the hood or inside the tranny belhousing
Old May 5, 2011 | 08:19 PM
dieseldude848's Avatar
the o/d solenoid is under the trans pan...... the link below has some pics of it.
2nd Generation Dodge Cummins - Code P0753 troubleshooting
Old May 6, 2011 | 07:47 PM
thanks for everyones help
AKDodge
May 14, 2015 12:52 PM
EverettsGMC
Mar 29, 2015 05:42 PM
rabidrabbit
Mar 6, 2015 03:47 AM
aoutlaw95
Mar 3, 2015 09:02 PM
rtbcoop
Nov 29, 2014 11:33 PM
