Crankshaft Position Sensor
Old May 4, 2011 | 07:54 PM
rogerz's Avatar
Default Crankshaft Position Sensor
Where is the location of the crankshaft position sensor on a 2006 Chevy Silverado HD 6.6 Turbo Diesel Duramax?
Old May 4, 2011 | 08:44 PM
veggimaxny's Avatar
i have an 03 and the sensor is a 2 wire plug on the bottom passenger side, front of the engine right below and/or behind the crank pulley. don't know if they are the same design in that respect but it shouldn't be far from that area. i'd start there. maybe there is a wiring diagram in your manual?
Old May 5, 2011 | 02:39 PM
rogerz's Avatar
thank you, you were correct it is located just below the crankshaft pulley. best to do is remove right tire, tire cover and the sensor is just ahead, again thanks, rogerz
Old May 10, 2011 | 10:23 AM
rogerz's Avatar
2006 Chevy silverado 6.6 duramax will not obtain highway speeds Maximum speed is 25 miles per hour Changed fuel and air filters, crankshaft and camshaft sensors with no improvement What is the problem?
1997silverado
Sep 7, 2023 06:20 PM
Shun70
Sep 20, 2015 10:52 PM
robbyS
Apr 16, 2015 02:22 PM
Moly Squid
Mar 28, 2015 04:26 PM
Jmohr52
Mar 4, 2015 01:18 AM
