Crankcase Vent Filter
Old May 2, 2011 | 08:18 PM
jac42779's Avatar
Default Crankcase Vent Filter
Have you guys ever changed your crankcase vent filter? Don't see anything about it in the maintenance manual. I adjusted my valve clearance today and that's what got me to thinking that maybe this filter should be changed at some time.
P.S. After having to adjust every rocker arm, my truck lost that annoying ticking
Old May 2, 2011 | 09:10 PM
dangerous1965's Avatar
Nope just let it be!
Old May 2, 2011 | 10:03 PM
DuramaxDiesel02's Avatar
Default Re: Crankcase Vent Filter
Are you talking about the steel wool/ metal mesh?? I know with the Detroit series 60 you can just take it out and wash it in solivent then wash off with water and let dry.
Sent from my Droid
Old May 3, 2011 | 08:27 AM
jac42779's Avatar
On the cummins motor theres a black box on top of the crankcase with two lines coming off of it. One goes to your blowby and the other is a return to the oil pan I think. I don't believe you can even open it up without destroying it.
Old May 3, 2011 | 10:10 PM
52deluxe's Avatar
How often are you supposed too adjust your valves?
Old May 4, 2011 | 08:31 AM
every 100k is fine.
Old May 4, 2011 | 09:16 AM
52deluxe's Avatar
How hard is it to do? What kind of tools will I need ? I've done it on my 52 chevy deluxe with an old 216!! I cant imangine its that much harder!!!
Old May 4, 2011 | 06:33 PM
jac42779's Avatar
I believe my owners manual says do it at 130k but I just did mine at 94k because they were ticking. Theres a pretty good write up on it in the dodge tech forum if I'm not mistaken, it's not too bad of a job.
jeffersonl
Nov 15, 2015 07:35 PM
markv8993
Jun 21, 2015 12:24 AM
Bob V
Apr 6, 2015 11:02 PM
LTreis702
Feb 14, 2015 12:52 PM
james2562
Oct 8, 2014 06:14 PM
