#6 injector leaking coolant
Old May 2, 2011 | 08:53 AM
bolster633's Avatar
Default #6 injector leaking coolant
Hi I'm new to your site. I have searched everywhere and haven't found a definite fix for my problem. I have a 95 dodge 12v cummins. I just put in new marine 370 injectors and 024 delivery valves. I had no leaks before I took it apart. After I got it running I noticed a small leak of coolant trickling down the back of the engine. Determined its coming from the #6 injector and running down the back. I torqued all injector hold down nuts to spec'd 44 ft lbs. Is there a coolant water jacket that the injector sits in? Or do I have a cracked head? I burn a mixture of 75% used motor oil/veg oil and 25% diesel fuel, with no mods. Thanks in advance.
Old May 5, 2011 | 06:17 AM
bolster633's Avatar
Anyone?
Old May 5, 2011 | 08:17 AM
biged681985's Avatar
the coolant is by no way coming from the injector. it could be a poped HG. or when you were doing the injectors, u could of hit one of the heater core lines and put a small hole in it and its spraying, hitting the block. or it could be a freeze plug
Old May 7, 2011 | 09:18 PM
bolster633's Avatar
Whats a HG? And yeah i've thought it might be a freeze plug in the head, I live in Maine and the truck was from the coast so there's alot of rust. Thinking I could have gotten a pin hole in the freeze plug next to the injector. Has anyone ran into this problem? I know some have blown the plug out the rear of the head, but is that a possibility that the head freeze plug next to the injector rotted out? Thanks.
Oh hg is headgasket. I thought that, but the truck runs smooth with no white smoke
Old May 8, 2011 | 12:10 AM
12Vdodge's Avatar
it could still be a HG. Mine has been leaking for months before i took it off the road to restore it, but it wasnt bad at all so i ran it. Now, if i had found oil in the coolant or coolant in the oil i wouldnt have ran it.
Old Sep 20, 2011 | 09:43 AM
bolster633's Avatar
The problem turned out to be a cracked head due to excessive pitting in the injector hole. Replaced the head, HG, and used ARPs to keep it all together
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Rayrock4
Aug 30, 2015 09:45 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
