looking for some input on a new turbo
Old May 2, 2011 | 07:09 AM
rlyncoal's Avatar
Default looking for some input on a new turbo
Here are the specs on an hx40 that I'm looking at let me know what you think
DESCRIPTION
Brand New, Has never been installed
4" Inlet Diameter
3" Compressor Outlet Diameter
T3 Flange Entry Exhaust Inlet
3" Exhaust V-Band Outlet
Journal Bearing - Wet Float Type
Oil Lub/Cool
600 HP+
Wastegate set at 20 Psi
Exhaust Housing 14cm
Compressor Wheel
72 lb/min Air Flow
8 Blades
Ind: 56.60 mm
Exd: 74.71 mm
Trim: 54.8
Turbiner Wheel
3" V-Band
Ind: 76 mm
Exd: 58 mm
Here is a link.
Amazon.com: Dodge Diesel Turbo Charge HX40W HX40 Cummins Engine Replacement of Garratt and Holset: Automotive Amazon.com: Dodge Diesel Turbo Charge HX40W HX40 Cummins Engine Replacement of Garratt and Holset: Automotive
Old May 2, 2011 | 08:37 AM
cumminskid92's Avatar
i have heard alot of bad things about knock off holset turbos. 300 is really cheap even for a used holset hx40. plus i dont think there is anyway a 40 would handle 600hp. someone else with a little more info about it will chime in.
Old May 2, 2011 | 11:10 AM
Levi Miller's Avatar
hx 40 should have a 4in down pipe and exhaust housing sounds like a knock off butt thats just my 2 cents
Old May 2, 2011 | 01:09 PM
white93's Avatar
Thats a Chinese one. For one it doesn't have the Holset tag on it and two, you can't get a ex housing smaller than 16 cm for those.
Old May 2, 2011 | 05:37 PM
rlyncoal's Avatar
Thanks for the input guys I think I will just rebuild my stock and change out the exhaust housing it has a small oil leak.
Old May 2, 2011 | 05:44 PM
JUNK
Old May 3, 2011 | 04:02 AM
RSWORDS's Avatar
Don't waste your money. I would hate to see you get it and it eat your engine.
Old May 3, 2011 | 11:45 AM
if anyone wants an hx35 i have one thats got a smaller exh and a banks big head waste gate it just needs a compressor wheel and a rebuild kit great turbo just not enough for my truck so i bought a hi- tech
Old May 4, 2011 | 06:12 PM
sotomo's Avatar
Im looking for an up grade for my turbo whats a good site to look for one ???
Old May 4, 2011 | 09:54 PM
fatirishguy's Avatar
HEY levi what do you want for it? did it help from your stock turbo?
