48RE stuck in first gear. HELP!!!
Old May 1, 2011 | 12:02 PM
Smok'em's Avatar
Default 48RE stuck in first gear. HELP!!!
I have a 2006 CTD with auto 48RE. Did the borg wagner solenoid and transducer kit change around 16K miles ago. About 2 weeks ago something weird happened, after an hr ride to work, I parked the truck. Two or so hrs later I went to start it and it was dead. I finally got it to start and limped to a shop, then had it towed to another shop. Bunch of codes, trans temp and ABS together with a cel came up and then it would not start again. The mechanic called me saying they had pinned out the ECM and diagnosed it to be dead.
I moved the truck to a real diesel shop that specializes in Cummins engines and they go the truck running again, cleaned all harness contacts and terminals, cleared all codes and go the truck running with no more codes.
The twist to the story is that before i the truck broke down it was shifting perfectly but when I drove the truck out of the shop it was clinging on to first gear, once it got to second gear it would shift fine. Now the transmission is stuck in first gear
I dropped the pan yesterday to inspect the wiring and connectors but all seem well. Replaced the filter and put new atf +4 and still nothing, adjusted the front band and the truck still won't shift out of first gear no matter what.
ATF was not bright red but it had 16K miles on it, normal smell, not burnt nor brown in color and the magnet barely had any sludge on it. I checked all external connectors and wires and they all seem fine. I replaced the governor pressure solenoid and transducer last time I serviced the tranny because of a shuttle shift problem.
Could it be a bad solenoid again, could the whole cell/ecm codes had been thrown by a short caused by either the solenoid or transducer?
I'd truly appreciate any help
Old May 1, 2011 | 12:05 PM
Sounds like a bad sensor... find someone with a good diagnostic scan tool
Old May 1, 2011 | 12:14 PM
Smok'em's Avatar
Speed sensor?
Would this not throw a cel? There are no codes at this time.
Thanks
Old May 1, 2011 | 01:35 PM
Default Re: 48RE stuck in first gear. HELP!!!
Not always
Luke
Old May 1, 2011 | 01:53 PM
Smok'em's Avatar
Sounds like a possibility, I just searched for pricing and its just under $20, I might just order it tomorrow. I don't have anyone local with a scanner
Old May 1, 2011 | 03:05 PM
You need to find someone before you start throwing money at it.
Old May 1, 2011 | 03:36 PM
Smok'em's Avatar
Good point but, when I had the shuttle shift problem my 2 local transmission shops told me I needed a new transmission because it was shot... I replaced the governor pressure solenoid and fixed the problem. I can't even think what they'll say this time that the truck is stuck on first gear.
Two weeks ago an independent shop wanted to replace my "shot" ECM for $2400 and my fan clutch that was "bad" as well for $500... a real cummins mechanic cleaned the ECM out of codes and it runs like a top now. (did not charge me a single dollar) but he knows nothing about transmissions.
I am horrified of the dealership so I kind of figure $20 is worth the shot. I understand your point but I feel like I am dead in the water with no decent mechanics around.
Old May 1, 2011 | 03:55 PM
How many miles is on your transmission?
Are you sure its starting off in 1st and not 2nd?
Last edited by Diesel Dawgs Performance; May 1, 2011 at 03:55 PM. Reason: Automerged Doublepost
Old May 1, 2011 | 04:08 PM
Smok'em's Avatar
126k and no, I removed my edge so I can't be sure. I am assuming so because if I pull from first and try to manually shift to second and then D it won't do a thing.
Old May 1, 2011 | 05:09 PM
NadirPoint's Avatar
Default Throwing Money
I hate this, it is so common these days. They will collect parts and labor money for days and weeks and keep on doing it while the problem is still not fixed.
Who you gonna throw money at, the heehaws trying to rip you off or the truck? At least with the truck you may have some good spare parts left after you guess wrong.
