Which Injectors
Old May 1, 2011 | 11:56 AM
Klockmon's Avatar
Default Which Injectors
I am having trouble deciding on whether to buy ddp's stage 2 or 3.
I have a bhaf, and gds 60mm compressor So im wondering if thats enough turbo for the stage 3. Or if I'd need to go bigger. I plan on getting a smaller housing too in the future if that matters much.
Thanks
Old May 1, 2011 | 12:26 PM
901stgen's Avatar
Not trying to change your mind but make sure you check out other manufacturers before you overpay for DDP. I personally wouldn't go with DDP. Go with SDX or LBD.
Old May 1, 2011 | 12:43 PM
Klockmon's Avatar
ive been researching sdx as well. But i keep going back to ddp.
Old May 1, 2011 | 01:02 PM
tower_ofpower's Avatar
ddp uses all new bodies and so on, no core return. SDX requires a core and are comparable to ddp. i actually thought i paid less for my ddp's. eitherway both are excellent injectors
Old May 1, 2011 | 01:10 PM
Klockmon's Avatar
do you think the stage 3 would be too much for my turbo?
Old May 1, 2011 | 04:49 PM
big bad diesel 416's Avatar
Site Sponsor
I would not put DDPS in a 1st gen unless they were the rattle snakes
Low budget had a great injector and so dose SDX depending on what you want to do with the truck 5X0.12 or 5X0.14 are a great choice that makes for 90HP and 140HP heres side by side comparision Injectors that is the 2nd gen section but the prices are the same for 1st gens
Old May 1, 2011 | 05:19 PM
Klockmon's Avatar
Im just wondering if my turbo will be able to handle 100-150hp injectors.
I know SDX is cheaper and probably just as good. But even the sdx 5X.014 which are the equivilent(spelling error) will my turbo be able to handle it?
Its gds60mm and I think im going to get a 14cm wastegated housing for it.
Old May 1, 2011 | 06:36 PM
Marty Z's Avatar
I woud go with 5x0.12 SDX or ddp stage 2
Old May 1, 2011 | 09:08 PM
Site Sponsor
if you want a good injector now go with SDX or LBD 90HP 5X0.12
if you want a little more injector now so you can expand later go with the 140HP 5X0.14
Old May 2, 2011 | 11:21 AM
Levi Miller's Avatar
man i have 90 hp injectors in my truck and i had a 60mm gds with a 12cm wastegated exh and it is in about a million peices now, it would over spool and surge bad so i put on a hitech 64mm turbo about 2000 bucks butt the best ive spent i went through 2 hx35's and 3 h1c's in 3 months before i learned i need to quit lowballing and buy what i need if you do injectors a good turbo shouldnt be far behind
