Qustions about my a/c
Old Apr 29, 2011 | 06:31 AM
Billy D's Avatar
Default Qustions about my a/c
My a/c compressor isn't kicking on. The switch has power, no blown fuse, all worked last year, I know it's overcharged right now, it was converted to r134, and I was a dumb a@@ and overcharged it. Could the over charging be my problem?? My buddie seems to think it's a ground problem on the comressor(it has power as well), if I don't have a reclaimer, is there a way to "reclaim it" or should I just vac it down and start again. should I just go ahead and replace my a/c switch fer sh@ts and giggles?? I gota have a/c
Any help is always appreciated
Old Apr 29, 2011 | 09:36 AM
big bad diesel 416's Avatar
Site Sponsor
jump the comp manually with external voltage with the motor off see if you can here it click if it dose then start the motor and put the power to it see if things get cold hook your gauges up to it tho dont let that head PSI get to high or you will be in deep shi*
Old Apr 29, 2011 | 09:58 AM
RAW's Avatar
RAW
Remove a test port cap.
Grab a small screwdriver.
Take a deep breath and hold it.
Put screwdriver in the test port and depress the schrader valve.
Vent as much as you think is necessary, or until you pass out. (If you have gauges it may be more accurate)
Repeat.
Old Apr 29, 2011 | 09:59 AM
kieron_kohlmann's Avatar
AC clutch should have power all the time and is switched ground by the computer.
Old Apr 29, 2011 | 11:00 AM
cumminskid92's Avatar
Repeat.
Maclain Marsh
Jul 13, 2015 06:23 PM
Jladanyi
Jul 4, 2015 02:43 PM
joldfield
Jun 22, 2015 04:27 PM
CumminsCoalRoller24/7
May 5, 2015 08:55 PM
JasonG.
Ford Powerstroke 08-10 6.4L
Feb 26, 2015 08:51 PM
