bllack diesel ?????????????
Old Apr 29, 2011 | 12:49 AM
12valvecummins1994's Avatar
Default bllack diesel ?????????????
hi i was wondering if anybody has ever herd of black diesel andif it is safe to use or not i found it at Diesel substitute, not biodiesel, black diesel fuel from motor oil dewatering filters if anybody has done this pls let me know
Old Apr 29, 2011 | 07:51 AM
biged681985's Avatar
i havent done it in a pick up, but we used to run oil in the tank in our semis at work when we changed the oil.
Old Apr 29, 2011 | 04:59 PM
12valvetater's Avatar
You can run waste oil as fuel, but make sure it is filtered and water seperated really well. It can lead to coked tips.
Old Apr 29, 2011 | 05:37 PM
95Ky5.9's Avatar
what would be the best way to filter it if one was to decide to run waste oil? would a airdog be ok? or would that be to much for the pump
Old Apr 29, 2011 | 07:28 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
racor 1000 filters makes a good set up. they say it will catch 99 percent of water. also they have a 2 micron filter.
Old Apr 29, 2011 | 08:00 PM
madmikeismad's Avatar
You want to filter waste oil separate from your fuel system, or you'll be changing out filters left and right. I run it regularly, no issues. I've run 90/10 mixes before, just make sure you filter the hell out of it.
Old Apr 29, 2011 | 09:42 PM
filter before the lift pump and after the lift pump and filter it before you fill your tank.
Old Apr 29, 2011 | 09:48 PM
diesel pap's Avatar
yes take the racor and filter it to 2 micron and put it in a bulk tank or drum. then you can mix it in your truck tank filtered again.
Old Apr 30, 2011 | 04:40 PM
Bill10656's Avatar
runing it,60-40 ish no worries filter it before putting i tinth tank, i filter to 5 micron and still block small in line filters once a week. i fi go straigh tot the main spin on filter it lasts alot longer.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
May 28, 2015 11:45 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
