gotta talk dirty to her to get er to start
Old Apr 28, 2011 | 11:27 PM
Little Luke's Avatar
Default gotta talk dirty to her to get er to start
Ok I'm getting tired of having to talk to this big sucker like a dog to get it to start.
It starts "ok" when cold, or driving for less then an hour. If I driving it for over an hour, kill it, then try to start it back up within an hour, it takes around 20 seconds for cranking. It fires and then idles fine. no smoke, all filters just changed. I used my dads meter to check the ficm, and it read 64 volts...... so I'm assuming his meter is a dud. So I need to get my multimeter back from my friend and recheck it I guess.
The message center on the dash says the oil pressure is ok. I'll unpack my sct tommorrow and check for codes. I'll be getting an edge insight next week so it might help me out alittle.
So what else can I check into?
Old Apr 29, 2011 | 07:18 AM
Mdub707's Avatar
64 volts? What the heck?
Usually when they have issues starting hot and not cold it's a high pressure oil leak somewhere.
Could be the STC fitting (snap to connect) on the HPOP, they're pretty notorious for failing, and there is an upgrade for it.
Old Apr 29, 2011 | 09:49 AM
Yeah, 64 volts, screw the 58volt hot mod
yeah, I would imagine the little $10 meter isn't real good, I'll test it again sunday and get the real readout with my meter.
So, the fix it list keeps getting longer
Old Apr 29, 2011 | 12:49 PM
Mdub707's Avatar
I know it's discouraging, but think about those poor guys who don't know any better and aren't on the forums. At least you're here learning and trying to get it squared away.
let us know how you make out on that FICM. If it's dead or dying, shoot me a PM.
Old Apr 29, 2011 | 02:46 PM
yeah...... funny thing is I bought this thing because I was tired of working on my f150 with its 5.4 v8 every weekend..... I actually went to change the oil in my dads excursion with a v10 in it last weekend....... so much space under the hood...... felt kinda good working on something that I knew inside and out.... oh well, Always wanted to learn about ford's diesels anyway, guess this is my chance.
Old May 4, 2011 | 02:23 PM
ok, this is pissing mme off now. I though she just laid down on me at my buddies shop. I killed it for 20 minutes, it like to have never started back up. Lets go on and assume it is my hpop. will this be something I've got access to while doing my delete and cleaning the turbo? how can I tell if it is the pump that has gone bad, or if it the stc fittings. Or is this just one of these things if I'm in there replace it anyway. I've read about an upgraded cover, what about that. I just want to get my ducks in a row before I get into this. Only one more night of class then this thing goes up to my shop.
ok, one other thing, The icp sensor, I've read it would cause a hard restart, anyway to check it? Or am I getting off track?
Last edited by Little Luke; May 4, 2011 at 02:23 PM. Reason: Automerged Doublepost
Old May 5, 2011 | 03:47 AM
bismic1's Avatar
The 2006 pumps do not fail very often, I wouldn't just replace it. The STC fiting, the dummy plugs, and the standpipes are good items to replace. After that, I bet you are good to go. Check the IPR while you are into it. If the screen is not torn or deformed, it should be good.
Old May 5, 2011 | 07:05 AM
Mdub707's Avatar
Agreed. The HPOP will be easy to get to while doing an EGR delete as you're about 90% of the way there, but if it's not broke, don't fix it. Get it hooked to a scanner if you're concerned about it.
Old May 5, 2011 | 08:43 AM
biged681985's Avatar
while u can get to the ipr easier, go ahead and pull it, and see if there is any metal shavings on the screen, if there is, the hpop is worn. best way to find a high pressure oil leak is to have someone with a scanner that can shut the ipr off, is have it closed, pull the icp, put the correct size adapter in it with an air fitting on the other side, and use compressed air and the listen for air leaks
Old May 12, 2011 | 11:49 AM
Well, the previous owner of the truck stopped by. He heard I was having issues with it. I explained what it was doing and he told me it started acting like this after the local dealer reflashed it under warrenty. He had called the dealer back and told him the issues and he told him that was normal for that truck, which is the same crap they fes me. This add any clues or should I just stick with the STC fiting, the dummy plugs, and the standpipes?
I had my tools stolen, So I just picked up another 400 piece set, not half of what I had, but it'll get me by for now.
Oh, and that wrench light came one again today while cruising home.... not under a load, just cruising at about 60 mph. I pulled over, hooked up my sct, and nothing. when I got home, I shut her off, turned the key, no light, cranked and started like a champ. I came back 10 minuted later and tried to start it, same crap, 15 crank time.
