problems after p pump swap
Old Apr 28, 2011 | 08:11 PM
FIRST GEN. JAKE's Avatar
Default problems after p pump swap
ever since i swaped p pump on to my 93 i been having problems. when first got it running it popping and white smokeing and i bumped the timing some and fixed it. now a few weeks ago it started dieing on me right after start it up. it starts then runs fine for a little bit then starts studdering and dies then has hard time starting back up and runs crappy till throttle it some. i though maybe the timing slipped to i pulled the gear and sprayed break cleaner on the shaft and gear hole and blowed compressed air on it and bumped it a lil more then installed the gear. now when you start the truck it still dies and it idles differnt now. truck been sitting in the shop for about a week while i fixed my tranny and started it today and it died, started it back up and it hazes white/gray smoke at idle. drove it out the road and truck blows white smoke till the engine gets some heat into it. and still has a gray tint to it. im not sure what my problem is. i thought it was timing but ive fooled with it and still wont run right. truck seem to be alot faster and ran better after last time i bumped it. kinda think might be losing prime but not sure. any thoughts? every thing was changed over has a 215 pump off a 97 had local pump guy put another gov assmebly in it cause previous one was junk, also has 4 k gov springs, cut dv's, custom ground plate. injectors are used set of sposedly marines i got in the deal with the pump. running piston lift pump, 97 fuel filter housing, lines and all that.
Old Apr 28, 2011 | 08:24 PM
captain_stabbin's Avatar
when you set the timing, did you set it with the gauge?
Old Apr 29, 2011 | 12:06 AM
no i just bumped the engine back some to advance it. i know i need a gauge but at the moment i aint got 140 bucks to buy one.
Old Apr 29, 2011 | 10:03 AM
kieron_kohlmann's Avatar
Mine was doing the same thing. Running like garbage and would die. check your transfer pump pressure with a gauge.
Old Apr 29, 2011 | 10:21 AM
gone ropin's Avatar
check the lift pump and also check the pressure relief valve on the return line on the pump, sounds like your starving for fuel some, get the fuel issue resolved and then set your idel speed....
Old Apr 29, 2011 | 03:57 PM
i wanted to just put a airdog on it and not fool with all the stock crap for this very reason but 500 dollars is hard to come by at the moment. what do yyou mean pressure relief valve im not sure where thats at? aint no valve it the return line that i know of.
well i think i found the problem the return line had a bad kink in it and it was leaking some at the fitting where i went from the metal line to the plastic think i got it all fixed. but i still think my timing is off though
Last edited by FIRST GEN. JAKE; Apr 29, 2011 at 03:57 PM. Reason: Automerged Doublepost
Old Apr 29, 2011 | 04:55 PM
Pressure relief is built into the banjo bolt on the return of the pump.
Old Apr 29, 2011 | 05:47 PM
i thought maybe thats what he was refering to
Old Apr 29, 2011 | 07:15 PM
pukie370's Avatar
I had same problem and it turned out being the fuel cylinoid was not opeaning all the way.
Old Apr 30, 2011 | 12:43 AM
not the case here cause i have no fuel solinoid it has pull cable on it and spring, pretty positive its returning to run postion as it should. il double check it though
