Oil press
Old Apr 27, 2011 | 01:52 PM
olsmokie47's Avatar
Default Oil press
Whats the right oil pressure. Mine usually sits 2 1/2 Lines above L
Old Apr 27, 2011 | 02:05 PM
kieron_kohlmann's Avatar
Mines about in the middle when cruising. a little lower at idle.
Old May 1, 2011 | 11:53 AM
KD93's Avatar
Don't trust the factory gauge. Get a real one and put it in. Should cost you around $65 or so with tax and shipping. But it'll tell you EXACTLY what your pressure is, rather than some vague wandering needle from the factory.
Old May 1, 2011 | 12:28 PM
tower_ofpower's Avatar
yeah, the truck has ran on the first needle for 20 years, either the bottom end is indestructible or dodge has a major engineering flaw... not that the 2nd option has ever happened before once the truck warms up it runs about 45-50 psi. Ever since i plumbed my centrifuge into a full pressure port my pressure has dropped slightly but some manufacturers engine lights dont come on until like 18 psi.
Old May 3, 2011 | 11:27 AM
Levi Miller's Avatar
first gens are supposedrun at the lowest 20 to 25psi stock from the factory is what the manuel says mine runs between 45 and 60 usualy
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
jhprice
Mar 29, 2015 09:36 PM
coors_man_2005
Dec 15, 2014 10:23 AM
