new problem
Old Apr 27, 2011 | 07:26 AM
Sandusky11's Avatar
Default new problem
got a 06 6.0 and i just got it out of the shop for the egr delete kit install two weeks ago. yesterday after noon i was driving and it just died on me. the truck wouldnt start and eventually was towed. any ideas? batteries are new the ficm has been replaced 10,000 miles ago the fuel relay was just recently replaced. im out of ideas any help is appreciated
Old Apr 27, 2011 | 07:46 AM
Little Luke's Avatar
my buddies truck died in an intersection about a month ago, I think he said it was an issue with the high pressure oil pump. He ended up replacing the HPOP and the injectors. Runs like a top now.
Has it been hard to start???
Old Apr 27, 2011 | 08:01 AM
Sandusky11's Avatar
thats what i was afraid of. no the only time i had trouble startin was when the ficm was goin out and nothin since. its been a little cold hearted once its started but i figured the new exhaust and egr delete might have some say in that
Old Apr 27, 2011 | 10:01 AM
Mdub707's Avatar
Usually a dead truck like that, that just dies out of no where will either be HPOP or some other high pressure oil leak somewhere, or FICM's, I've seen them do this a time or two. Checking the FICM is really easy, to rule that out.
Have you tried scanning it for codes? FICM is easy to check... any good scanner should give you your pressure readings for the oil side too.
Old Apr 27, 2011 | 11:03 AM
Sandusky11's Avatar
i dont have a scanner so its at the dealership right now. they r gonna scan it and tell me whats wrong tom afternoon i guess. the warrantee expired one month ago so im seriously hoping its not the hpop or the injecters. when the ficm went out before it ran great but it just started harder and harder untill eventually it just stopped. any idea on aftermarket hpop's or just stick with oem? how much do they run
Old Apr 27, 2011 | 11:45 AM
Mdub707's Avatar
All 8 injectors wouldn't just die going down the road like that, sound sounds unlikely. IF they try selling you a bunch of injectors, I'd question the FICM first. I was with a buddy of mine when his FICM died on his while cruising down the road. He had been getting codes for a week, but just cleared them and ran with it. Truck died at 65mph out of no where, no restart. Dealer scanned and said it needed 4 injectors. 1,3,5,7. Why would 4 on one bank just go bad? they didn't, it was the FICM.
Hpop sounds like a good possibility here though. Aftermarket isn't really released yet, and especially not for the 05+ trucks. There is a billet one in the works and being tested, but so far they haven't proven to do anything. There are 6.0's making over 1000rwhp on stock HPOPs, just stick with a new stock one. Unsure of price.
Old Apr 27, 2011 | 12:23 PM
What I've seen is between $650 and $800, not sure on install. the ones for 05+ seem to be the more expensive ones.
Old May 2, 2011 | 08:57 AM
Sandusky11's Avatar
just found out its the hpop, dealership should have it back to me today, not sure what the final cost is just yet but they said its lookin around 1000. they said it was only pushin out about 45psi instead of the needed 500psi haha. thanks for the help guys
Old May 2, 2011 | 09:44 AM
Mdub707's Avatar
No warranty? I know my 06 is up end of August this year... or are you over on miles?
Old May 2, 2011 | 12:09 PM
Sandusky11's Avatar
its got 94000 on it and i think the warantee date was march 15 however i dont have any egr, and the catalytic conv was removed so the warrante was terminated
