Need some help with throttle linkage rod
Old Apr 26, 2011 | 08:27 PM
Rusty89Cummins's Avatar
Default Need some help with throttle linkage rod
Alright so i bought some new ends for my throttle linkage rod for my pump from McMaster-Carr. I thought they would just snap over the pins like the old ones do but they dont. I though i saw someones setup before on here where it did. Anyone know what i have to do to use them? I was thinking a bolt to replace the pin on the arm on the pump, but i dont know what to do with the other one thats on the bracket thats connected to my throttle cable because its not bolted to it. Any help would be great.
Old Apr 27, 2011 | 12:06 AM
sweetv8s10's Avatar
I would grind it off and put a bolt in it it should work fine I would think.
Old Apr 27, 2011 | 07:40 AM
ya i was gunna do that as my last resort. i just wanted to see if there was another way. but ill probly have to do it that way.
Old Apr 27, 2011 | 08:34 AM
SNOOT's Avatar
Cut them off it may have been my truck you saw. I can try and get you a picture. Get a small spacer and new bolts. Make sure you locknut the bolts.
Old Apr 27, 2011 | 09:36 AM
ok thanks. a picture would be great if you had one.
Old Apr 27, 2011 | 01:48 PM
olsmokie47's Avatar
I put a turn buckle on mine. Lol goin down the road and slowly losing throttle. Look over at dad and this is all I hear " I told you to take it easy on the 3 in 1 oil" so yea all I had to keep the turn buckle tight is some wire and blue permatex .
Old Apr 27, 2011 | 01:49 PM
nice.
Old Apr 27, 2011 | 02:06 PM
kieron_kohlmann's Avatar
I think you got the wrong part. Mine came with new ends and a rod that used the same *****. I got it maybe 3 months ago.
Old Apr 27, 2011 | 09:22 PM
fatirishguy's Avatar
I just replaced mine, Got them from diesel shop in my town 40 bucks, New rod and lock nuts with 2 new ends. The only thing I dont like is that the new rod is not as big as the new one. old was like 1/4-20 and the new one is alot thinner. I kept the old one which was just bent as a back up.
Just looked at picture again and you have a small hyme joint end and what you need is the ball joint. 1 right hand and 1 lefthand.
Last edited by fatirishguy; Apr 27, 2011 at 09:22 PM. Reason: Automerged Doublepost
Old Apr 27, 2011 | 10:03 PM
SNOOT's Avatar
