Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
Wooster, Ohio truck and tractor pull-May, 7th 2011
Old Apr 26, 2011 | 08:15 PM
sixinarow07's Avatar
Default Wooster, Ohio truck and tractor pull-May, 7th 2011
Wayne County Truck and Tractor Pull
May 7, 2011 (Rain date-May 8)
Wayne County Fairgrounds- Wooster, Ohio
Tractor Classes: 9am
Truck Classes: 4pm
Tractor Classes: $20 Entry Fee
Stock: 1975 and older, 4MPH speed limit, Engine must match make of tractor, Cut tires allowed, nothing larger than 18.4 tires, No turbos, Judges decisions are final
Open: No tires larger than 18.4, Must surround complete rotating clutch assembly 360* with minimum of 3/16” steel, ¼” aluminum, or use a SFI 4.1 or 4.2 blanket. Blanket must completely surround clutch. Two blankets may be used to accomplish this.
3500lb Stock
4000lb Stock
4500lb Stock
5500lb Stock
5500lb Open
6500lb Stock
6500lb Open
8500lb Stock
8500lb Open
5500lb V8 -6000 RPM Limit
5500lb V8- No RPM Limit
16,000lb Open Tractor (No Tire Limitations)
For any questions on the tractor class, call: Jim Flinn (330)-465-4397
Truck Classes: $25 Entry Fee
Evening truck classes will start at approximately 4pm
6200lb Street Stock Gas Truck Rules:
26”hitch(no exceptions), Must pull from Reese style hitch, No trick hitches
DOT tires only
Factory fuel injection or single barrel carburetor(No dominator carbs)
Naturally aspirated, No Nitrous, No water injection, No propane
Minimum 1’’ of suspension compression is required
Must have exhaust that exits behind cab
Current plates, registration, and valid insurance required
All trucks must be street legal, judges decisions all FINAL-No whining
Hanging weight allowed but must not exceed 60” from center of front axle
Open Gas Truck: 6200lb
26” hitch(no exceptions)
DOT tires only
Naturally aspirated, No Nitrous, No propane, No water injection
Hanging weights allowed but must not exceed 60’’ from center of front axle
Front and rear u-joint shields are required(No exceptions)
Trucks must have blow proof bell housing, scatter blanket and SFI approved clutch
Diesel trucks will follow NADM rules
1-6200lb Street Stock Gas
2-6200lb Open Gas
3-8000lb Work Stock Diesel( Hanging weights will be allowed)
4-8000lb 2.6” Diesel
5-8000lb Super Street Diesel
6-8000lb Open Diesel Truck
For information on truck classes call: Brandon(330)-749-8947 or Karl(330)-624-7000
*No alcoholic beverages permitted on the grounds*
