how much lift on stock Radius Arms??
Old Apr 26, 2011 | 07:43 PM
jayman54's Avatar
Default how much lift on stock Radius Arms??
i got a 94 dodge ram with a 3" body lift and 2" daystar buckets. i'm currently running 37's with now issue but there very close to the rear of the fender under full turn. i want new tires as mine are gettin low on tread and i know with new tires its gonna be even tighter...i was thinking about goin with a 4.5" or 5" spring and losing the buckets giving me a 2.5-3" over what i have now...i plan on getting the adjustable track bar. possibly a drop pitman arm if i need it...i just need info on the front, my local spring shop can tweak the rear... i plan on goin with a long arm later, just trying to do it a little at a time with out breaking the bank...
Old Apr 27, 2011 | 11:44 PM
jayman54's Avatar
really nobody's got any info on this???
Old May 2, 2011 | 04:48 PM
Get_ER_Cummin's Avatar
most lift on a stock control arm is 3". befor the tire just not center anymore and starts to kill tie rods and such. i make a long arm kit to fit your needs if you interested let me know
Old May 2, 2011 | 10:53 PM
jayman54's Avatar
wouldn't mind more info on the long arm kit
Old May 3, 2011 | 10:16 AM
1AMatt's Avatar
Site Sponsor - 1aauto
3 inches is doable but pushing it on stock control arms. If you go to a 4.5" spring you will DEFINITELY need new shocks, and probably upper, as well as lower control arms. A drop pitman arm is a must, as well as an adjustable trac bar.
Old May 3, 2011 | 04:55 PM
L_Lemmon's Avatar
i pieced together a 6 in lift and didnt run a drop pitman arm.. but you will deff need to put a lover contol arm for 4.5 in lift and any thing over that both upper and lower
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
