vacuum pump?
Old Apr 25, 2011 | 08:33 PM
zach_west's Avatar
Default vacuum pump?
Does an 03 have a vacuum pump and if not how is the a/c controlled? i've been wondering this so i know how to do my vacuum pump and powersteering pump when i do my 12v. thank you for any help
Old Apr 25, 2011 | 09:29 PM
white93's Avatar
I think the blend doors for the hvac are electric and the brakes are hydroboost. I don't think the 3rd gens have a vacuum pump but I could be wrong.
Old May 1, 2011 | 09:58 AM
tennman's Avatar
The 03's and early 04's have a vacuum pump that is used for the cruise control.
The pump is located on the passenger side in the rear corner behind the battery.
Old May 1, 2011 | 08:21 PM
zach_west's Avatar
ok i'll look for it tomorrow. how is it ran?
Old May 1, 2011 | 09:20 PM
tennman's Avatar
There is a elect. plug on the side of it.
When you first turn the key on it will run for a few seconds to fill the line up.
If you have no vacuum leaks it will shut off and then cycle as needed.
Old May 1, 2011 | 09:25 PM
zach_west's Avatar
i'll have to look at a schematic for it. I'm wondering if it is also ran off of my ecu. I shouldn't have a problem with a cruise operating then when I put my 12v in then
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
InheritedDiesel
Apr 17, 2015 07:20 PM
DeLuzGN
Mar 17, 2015 08:08 AM
