Front UJ Service
Old Apr 24, 2011 | 03:05 PM
Bill10656's Avatar
Default Front UJ Service
Since driving my truck with the windows donw i noticedc a funny noise. i want to grease my ball joints which meant the wheels needed removing....Anyway I noticed the UJ's at the end of the axle were in a very bad way! Now its a national holiday here for the next few days so i can;t find out how easy these parts are to get. But first i need to know fomr you guys if they are serviceable or not, they don;t look it but i just wanted to check. So can the UJ alone be replaced or do i need to buy full shafts?
RockAuto Parts Catalog
I have found some shafts here, the prices vary wildly can anyone give me some guidance on the difference betweent hem as its all numbers and know nothing about them. the more expensive ones include the seal and bearing but individually these part sonly add up to about £30 per side, but the kits are over £100 more than the one not including them...So i'm a bit confused and need th etruck back in top condition asap for work!
Thanks for your help guys
Old Apr 24, 2011 | 06:11 PM
12valvetater's Avatar
You dont need shafts. Put spicer non greasable joints in. Before anyone calls me out on servicable/non serviceable joints think of it like this. When most of you grease something do you really take the time to wipe the dirt and crud off of the zerk? Also I never run a greaseable in the axle for one reason greaseable joints have a cross in them to allow grease to be pumped out to the caps. This makes the joint weaker. The joints in the streer axle are under the most load and if there is one joint you dont want to have break it is that one.
Old Apr 25, 2011 | 06:34 PM
Bill10656's Avatar
Excellnt, on furthe rinspection my drivers side shaft has alot of play in it also, so i guess th ebearing for this need's replacing, are they simple to remove and replace?
ALso alot fo the product si'm dining that are supposedly for the 2500 say dana/spicer 44 and dana, I thought these trucks had a Dana 60 front axle?
Sorry, thirs post ina row, If anyone could point me itnhe right direction for the exact dimensions of the U joint that would be great a si could then try to source them locally.
shingi
Off Roading
Sep 30, 2015 11:17 AM
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
Slim Whitey
Wanted To Buy (WTB) - Used
Mar 3, 2015 06:15 PM
Natenelson1
Jan 19, 2015 07:23 PM
